Old 06-19-2009, 02:30 AM   #1 (permalink)
Default KL650 starting problems
Hey Guys,
When I bought this motor, it wouldn't run at all. While I was cleaning the carb I found that the idle jet was clogged up. After I cleaned and reassembled, It runs. But, it still has quite a bit of trouble starting. After it starts it runs fine, but I dont like the fact that it takes 30 seconds to start it. Let me know what you think.
EDIT: Carb is a CV. Cams look good. oil possibly had another fluid in it.
Hope this helps.
-Jay
JaySea20 is offline   Reply With Quote
Old 06-19-2009, 06:41 AM   #2 (permalink)
Default Re: KL650 starting problems
Change the spark plugs and put clean gas in it. Had a similar problem and that was the fix.
Gotted is offline   Reply With Quote
Old 06-19-2009, 08:34 PM   #3 (permalink)
I hade a KL650 motor, would only start if no throttle.
MC@ Performance Fab is offline   Reply With Quote
Old 06-21-2009, 02:22 AM   #4 (permalink)
Thanks for the input guys. I think that I found the problem. The choke did not have a cable on it. When I rigged an choke cable and solenoid up, and sealed it, it starts fine.
choke on a switch. it's pretty cool, for a noob. lol
Thanks.
-Jay
honda odyssey overheating problems fl250dirtslinger The Pilot & Odyssey Forum 3 10-27-2008 11:31 PM
rhino problems r6eric The UTV Area 11 08-24-2008 05:12 AM
having problems getting hand brakes to work stress Controls and electrical 16 08-22-2008 08:48 PM
starting a build using parts from 2 john deer gators oppie Projects in Progress 1 02-10-2008 07:58 PM
Problems getting my CBR 600 F4 fired flyerrider Motor - Engine 29 01-05-2007 02:21 PM
