#11 (permalink) |
some late model cars use fuel systems that dont have return lines.there is a pressure sensor at the end of the fuel rail.the ecm pulses the voltage to the fuel pump.as the goverment clamps down on emissions standards there will be more sensors and electronics to deal with.
#12 (permalink) | |
OK need some clarity here. You keep saying after the fuel rail. Unlike the Busa the 1000 only has a single input on the fuel rail. So how do I place the regulator after the fuel rail? The fuel setup now looks like the below. Code:
* * * * * * * * * * * * * * * * * * * * * * * * * * * *|--->Flow Meter * * * * * * * * * * * * * * * * * * * * * * * * * * * *| Tank Fuel Pickup--->Fuel Pump--->Regulator--->Fuel Rail * * * * * * * * * * * * * * * * * * * * * * * * * * * *| * * * * * * * * * * * * * * * * * * * * * * * * * * * *|--->Bypass to Tank Here's the Hyper setup http://www.hyperracing.com/docs/standar ... ection.pdf Looks like they just use the single bypass to the tank and plug the other output port. Unless I'm looking at the drawing wrong. Confused yet? I am [smilie=banghead.gif]
#13 (permalink) |
rusty, remember when we tried to use your regulator on the return side? by doing that you keep all the volume at the injectors and bleed off the return line to the tank. This way the pump never gets bogged down with a heavy load from not being able to run at the rpm it wants to operate. *I use the "hyper "system on my race car and it works very good. Mike Dicely machines his own fuel rail that has 2 ports, one for entry and an exit which is were the fuel bypass regulator goes. *Again, the bypass regulator has to work off the return line not the main pressure line. if the regulator was on the pressure side, then volume is comprimised to get the pressure to 43 lbs.
#14 (permalink) |
Yeah Rich I've been looking into this issue further since I posted last. You're right on the mark. Good thing I started looking into this issue, Kevin is a little over anxious to get out and run this thing. With the pump setup this way it wouldn't be long before it burnt out.
Spoke with the guys at RCC Turbo concerning this issue. According to them there are three ways to solve the problem.
RCC has fuel rail inserts for $25. Nifty little units that is easy to install. http://www.rccturbos.com/rcc2005/index. ... tail&id=59 Since there is no Turbo on this engine RCC suggested we just use a t-adaptor. Although they would be more then willing to sell us a fuel rail for $275. I'll let Kevin decide which way he wants to go. Anyone want to take bets on which option he goes with?
