Old 12-23-2006, 02:46 AM   #1 (permalink)
Default Motorcycle engines etc...
ok so im looking for an engine between 550 and 800 cc, either a motorcycle engine or a snowmobile engine.
Where could i get one? and which type would be a better choice...snowmobile or motorcycle
desertracer543 is offline   Reply With Quote
Old 12-23-2006, 02:49 AM   #2 (permalink)
Send a message via MSN to Racerj404
Default Re: Motorcycle engines etc...
you can find them at ebaymotors.com
Racerj404 is offline   Reply With Quote
Old 12-23-2006, 02:50 AM   #3 (permalink)
yoshi's Avatar
lets try this, what is it going in, specs please...
www.sinistersandsports.com
Old 12-23-2006, 02:53 AM   #4 (permalink)
honda odyssey fl250 similar to this...
http://www.dunebuggy.com/members/viewPh ... otoID=5645
he is selling a kit and he has a 700cc snowmmobile engine placed in his
Old 12-23-2006, 03:02 AM   #5 (permalink)
Administrator
K-fab's Avatar
Sled engine - two stroke 800 triple makes about 165 to 180 hp stock - they can be made to make sick amounts (for the size) with mods. *600 EFI makes about 120 or so. *800 twin - 140ish.
Two strokes are unfortunately LOUD, drink fuel, need to be re-ringed fairly often, require premix or oil injection. *Can be carbs or EFI.
Sled engine - four stroke. *Killer things they are! - hard to find they be.
GOBS of torque. *(all Yamaha) 500cc twin makes 80 hp, 750 cc triple makes 120, 1000 cc four cylinder makes 155ish.
I went from a 1000 triple two stroke (made 185-190 hp) to a 1000 four cyl four stroke and the car is so much better it's not funny. *Not as much hp, the the torque does all the work and does it wonderfully.
The car is dramatically quieter, the FI system is a kick to tune and it'll spin the tires with ease.
It doesn't drink fuel like the 5 mph two smoke did... - not sure yet, but it seems to be closer to 15 mpg now.
A sled engine is a ripping engine for a buggy - but you have to run a CVT setup (which is my personal favorite).
CVT has the advantage of always being in the engine's powerband. *Properly tuned, they let the engine come up to peak power and then the clutches transfer the "gear ratio" on from there. *Makes for one hell of a fun ride.
Motorcycle - easy to get, make good hp - select your size and you select your hp. *I'm not into bikes, so I can't give you any specific numbers other than the Busa - 186 hp. *1300cc also...
Pain in the butt to shift all the time. *Always having to find the right gear... *Get out of the power band and you loose drive.
I ride a motocross bike, so I'm used to shifting to keep it in the power - I just don't like to in a buggy.
I've driven both types - cvt and motocycle powered cars and I'm sold on the CVT setup. *It's just so much simpler and works just as good, if not better.
Hmmm - wonder why sleds don't have gears???
Old 12-23-2006, 03:20 AM   #6 (permalink)
where woudl you recommend to get a sled engine?
Old 12-23-2006, 03:23 AM   #7 (permalink)
Administrator
K-fab's Avatar
For an FL250 - nowhere... *That's not the chassis to put anything more than about 30 hp in...
For another chassis with suspension and a roll cage (not bar) I'd look at e-bay or one of the wrecked toy sites. *Sorry, I can't recall the name of the one that has so many... *Tried a search but don't find it.
Old 12-23-2006, 03:57 AM   #8 (permalink)
its an fl250 which will be modified w/a roll bar, extended a-arms, suspension etc...click on the link i posted for an example pic
Thanks
Old 12-23-2006, 04:34 AM   #9 (permalink)
I wouldn't do it, there's just so much wrong with the idea. It would cost a lot of time and money to modify a FL 250 and when you're done, it would be sub standard.
If you can modify a chassis, you're capable of building one from scratch.
