I have a problem with the board time clock which came about after the board change happened. * :?:
I can edit my profile and everything is ok for that session as long as I don't close down the Firefox browser. *However, when I open up Firefox and go to Minibuggy.net, the forum time is off but it still recognizes my login cookie. *This doesn't seem to happen with IE, but I rarely use it anymore. What am I doing wrong? |
#2 (permalink) |
I'll have to install Firefox and test the site. Seems to work fine with IE and Opera. The time settings are stored in the database and not the cookies so I don't know why it would be throwing you off. Did you delete your cookie? Browse to your temp net files and sort by extension. Look for "cookie:your_name@www.minibuggy.net" and delete that cookie. Replace "your_name" with your windows login name. This should save you from having to redo passwords for other sites if you use auto login. Personally when I close my browser all cookies, history and files are deleted.
#6 (permalink) | |
#7 (permalink) |
I went into the database and set your time to manual mode + server time. See if that helps, this is the setting everyone should be using. I left your GMT offset alone at -7 hours. Are you in Az? Pac time is -8.
-R
#8 (permalink) | |
BTW, I like the new emoticon selection. *[smilie=thumbs_up.gif] |
