Thread: MX Bike Buggy
Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 80 of 80
    Re: MX Bike Buggy
    #71
    Well I finally got back to some Saturday work. I got the rest of the golf cart stripped, now I just need to sell or scrap out the carcass, the frame being aluminum I should be able to get some $ out of it. Then I will get the bikes lined up again and start bolting them together, I can get the rear axle out of the GC narrowed and the axles modified to take the drive sprockets from the bikes. Seeing progress, renews incentive to get back to it!IMG_3972 (1).jpgIMG_3968 (1).jpg
    Re: MX Bike Buggy
    #72
    OK, I got rid of the Golf Cart frame so I now have the "Shop" back to continue the build. I have the bike chassis attached with some all-thread to set the width, and have purchased some perforated aluminum tubing to attach the bottom of the frames together. That should happen Sat. then I can cut the frames apart and set the wheelbase.
    Re: MX Bike Buggy
    #73
    45w...? One 2' x 4' panel can produce 300-400w.
    Re: MX Bike Buggy
    #74
    Well, I'm back after a long absence due to medical issues, a kidney transplant. I made it to my "shop" Sat. and dusted everything off, it had been a while since I had even seen the buggy! Anyway. I made some progress on the frame rails, by screwing together two of the steel home framing stud tracks to make a box section. It came out quite strong, even with only the wide spaced screwing pattern! In final construction I will used Aircraft Blind rivets, with a tighter pattern as needed. The golf cart drive axle will get the drive sprockets mounted to the axle flanges to drive the rear wheels with the MC chains. I need to replace the short axle and housing with another long side to get wide enough, "Should" be an easy fix. Next shop day I'll be mocking up the seat frame to get the rear spring setup sorted out.
    Re: MX Bike Buggy
    #75
    The frame tubing progress....
    Re: MX Bike Buggy
    #76
    Sep 2014
    West Palm Beach FL
    Wow! Kidney transplant? Glad you're ok.
    Re: MX Bike Buggy
    #77
    Glad to see you're back. Not letting some stinkin' kidney transplant slow you down!!!
    It will be worth it. Trust me.
    Re: MX Bike Buggy
    #78
    Did you wake up in a bathtub full of ice?
    Glad to hear things are good and that you're up and running.
    Re: MX Bike Buggy
    #79
    Frame tubing?!!! That's house metal 2x4's. You would be better off with Aluminum foil.
    Re: MX Bike Buggy
    #80
    Ive made scaffold picks out of steel 2by, very strong! I weight about 430lbs and they hold no problem.
    I don't think you understand what hes building?
  1. TTGInc's Buggy Build 2.0
  2. who to talk to about buggy plans?
    Last Post: 05-05-2013, 01:23 AM
  3. WTT 2009 R6 Limited Edition for a buggy
    By stevieterry in forum For Sale
    Last Post: 04-16-2013, 09:36 PM
  4. Bike engine/ 1000lbs buggy
    Last Post: 11-14-2010, 03:43 PM
  5. My new buggy/ kit car project
    Last Post: 01-07-2009, 07:22 AM
