The Litter Box Want to be Totally Off Topic? Debate ideas? Banter about things that don't fit anywhere else? This is the forum to use! If you're easily offended, you may not want to enter this forum.
Old 04-06-2008, 06:39 AM   #11 (permalink)
plkracer's Avatar
Default Re: Anyone know anything about Dodge diesels
Originally Posted by diirk\";p=\&quot View Post
It could be the lift pump starting to go bad. It's a common problem on some years where the it's an intank pump.
Would that cause a high idle though? I saw that on those dodge forums, but that was related to stumbling, or no power after so many rpm.
It finally moves!
Old 04-06-2008, 04:20 PM   #12 (permalink)
busasandrail's Avatar
Im with you on this one....sounds like a lift pump.
Youll need to hook up a pressure gauge in the low pressure side of the fuel system to check it out.
Dodgetalk.com has a desent forum section.
Nothing is impossible---it just costs more money.
EL TORO sand car w/(soon to be) TURBO 1397 Busa / Subaru STI diff. / cutting brakes
www.eltorosandcars.com
Old 04-06-2008, 06:42 PM   #13 (permalink)
try inline diesel.com
trudchaser is offline   Reply With Quote
Old 04-07-2008, 05:44 AM   #14 (permalink)
Thanks,guys i'll be hitting on it hard monday. Got to get it going quickly.
boilermaker is offline   Reply With Quote
Old 04-07-2008, 11:43 PM   #15 (permalink)
Philabuster's Avatar
Dead pedal is usually the APPS (accelerator pedal position sensor) going out. *A new one from Dodge is about $400-$500! *
The guys on Turbo Diesel Register have built a replacement kit for about $150.
[url=http://www.turbodieselregister.com/forums/24-valve-engine-transmission-1998-5-2002/198522-anatomy-apps-sequel.html:2mgj8pc1]Cummins APPS thread on TDR[/url:2mgj8pc1]
Philabuster is offline   Reply With Quote
Old 04-07-2008, 11:51 PM   #16 (permalink)
plkracer's Avatar
Nice find. Looks liek you can find them in the 150 area for pretty much a direct replacement.
It finally moves!
Old 04-07-2008, 11:53 PM   #17 (permalink)
You don't need a scanner for codes. *Just turn key on-off-on-off-on (don't start it!) and read the codes-if any-in the odometer display.
DTR is another GREAT forum. *It doesn't require paid membership to post--just like this GREAT place! *
http://www.dieseltruckresource.com/dev/index.php
Old 05-23-2008, 06:25 AM   #18 (permalink)
tell me the codes.
As prev stated its most likely the apps.
I see more ford and dodge diesels in my shop than anny other.... mostly fords *[smilie=big_explode.gif]
not vary many dmaxes unless they are getting efi live'd
^ my turrddddd
Madspeed is offline   Reply With Quote
