The Litter Box Want to be Totally Off Topic? Debate ideas? Banter about things that don't fit anywhere else? This is the forum to use! If you're easily offended, you may not want to enter this forum.
Old 12-27-2008, 03:41 AM   #1 (permalink)
Send a message via AIM to southernford246 Send a message via Yahoo to southernford246
Default sizes
what is 40x40x2mm, 30x30x2.3mm, and 20x20x1.6mm box tube in inches rounded off to ???
southernford246 is offline   Reply With Quote
Old 12-27-2008, 01:26 PM   #2 (permalink)
Default Re: sizes
40mm=1 9/16"= 1.575" 30mm=1 3/16"= 1.18" 20mm=11/16"=.787" 2.3mm=3/32+"=.09" 2mm=3/32-"=.079" 1.6mm=1/16"=.063" These are close, I used my digital caliper. Tim
tooltime is offline   Reply With Quote
Old 12-27-2008, 03:18 PM   #3 (permalink)
Default Re: sizes
what is the difference between flats, plates, and sheets of steel????
Old 12-27-2008, 03:20 PM   #4 (permalink)
Send a message via Yahoo to vidio1
Default Re: sizes
A mil is .03937 or .040 when guestimating. Just in case the need comes up again. So 40mm x .03937 = 1.5748 inches. Here's a link to a printable decimal to fraction chart:
Decimal & Fraction Equivalents Chart
vidio1 is offline   Reply With Quote
Old 12-27-2008, 05:23 PM   #5 (permalink)
Super Moderator
minibajaman's Avatar
Default Re: sizes
The conversion is millimeters divided by 25.4 equals inches.
So 40mm / 25,4 = 1.575 inches.
Or get this unit conversion program for all your converting needs.
The thickness. I don't know exactly what the limits of each are, but let's say Flats are usually thick, like 1/2" or more, plate is maybe 1/8" to 1/2" thick, and sheet is 0 - 1/8". It doesn't matter what it is called, as long as the size is what you need.
Old 12-27-2008, 10:46 PM   #6 (permalink)
Default Re: sizes
do you guys think a combination square would be able to mark out the angles ???
Old 12-28-2008, 07:43 AM   #7 (permalink)
onlyguy's Avatar
Default Re: sizes
dont fight it, go metric. the sooner you change the easier it will be!!
its the whole quart thing that eats me up. drop those mofo's
god bless america
onlyguy is offline   Reply With Quote
Old 12-28-2008, 04:53 PM   #8 (permalink)
Default Re: sizes
Neverrrrrr That's how it all starts, first the Metric system and before you know it someone will want to run 50 hertz power to their Garage
Old 12-28-2008, 09:28 PM   #9 (permalink)
Administrator
K-fab's Avatar
Default Re: sizes
god bless america
I'm fine playing w/mm and volume but WTF are Celsius and Pascal? Those make absolutely NO sense... Someone says it's 35 degrees and it's hot?
Last edited by K-fab; 12-28-2008 at 10:14 PM. Reason: I made a grammatical error! The world will end 37 minutes from now. Drats.
Old 12-28-2008, 10:05 PM   #10 (permalink)
XRH348's Avatar
Default Re: sizes
or degrees kelvin for that matter, and its not one of the chipmunks
XRH348 is offline   Reply With Quote
R1 Street Bike Sprocket Sizes to start with? ffjosh Driveline 7 12-10-2008 08:36 PM
Tire Sizes & Squish for design Engineer Suspension - Wheels & Tires 15 10-21-2008 08:34 PM
Brake Line sizes?? stetler Controls and electrical 13 10-08-2008 01:38 PM
All your tubing sizes (weldments) standfast File Library 0 06-20-2008 06:09 AM
Sprocket sizes... yoshi MiniBuggy.net Lounge! 4 09-23-2006 01:41 AM
