Results 1 to 10 of 16
    CNC plasma/laser cutting?
    Does anyone know of a place that can cut a few custom tabs for my project? I can provide DXF files for the parts. I have emailed a couple of companies but havent got any responses. It is on 4 tabs out of 1/4" material. Maybe its not worth the time....
    Re: CNC plasma/laser cutting?
    Senior Member JD66's Avatar
    Jan 2013
    San Diego, CA
    What area are you in? I use a local waterjet place for my stuff.
    Also, if it's a common tab size you can probably buy a premade part online or a local off road shop
    I'm in Kansas. I have looked at every tab website that is out there. I am running heims with a 1" through bolt and can't find any tabs that look like they will work for that. I have drawn what I know will work perfect but can't find anyone to cut them.
    Jan 2013
    San Diego, CA
    Maybe these guys? https://www.bigbluesaw.com/index.php...mator&itemid=0
    Try searching online waterjet or online CNC plasma?
    K. Ill check it out. Thanks!
    http://www.google.com/url?sa=t&rct=j...61965928,d.dmQ
    These guys will do it.
    You can go right to Miguel,
    Miguel Hernandez (mhernandez@gkmachine.com)
    I looked into them earlier but thought they looked like a big company to cut parts for the little man. I sent him an email. We will see what they say! Thanks
    I just had about 8 pieces of 1/8" and VERY small done a month ago, no problem.
    Give Miguel a minute, he'll get back to you.
    I have a 5x10 plasma and can handle up to 1-3/4" material. Email me your files and I'll get you a quote. Yoshi@sinistersandsports.com
    www.SinisterSandSports.com
    918-521-3736
    Whats a piece of 1-3/4", 5' by 10' weigh? Damn!
  1. ST4 laser cutting quote
    By Promod1955 in forum ST4
    Last Post: 10-14-2011, 02:02 PM
  2. Plasma Cutting Brake Rotor?
    By rgvkid in forum Driveline
    Last Post: 03-04-2011, 04:29 PM
  3. cutting brakes with bike motor
    By allanejames in forum Driveline
    Last Post: 02-09-2011, 10:54 AM
  4. cutting and rewelding tubing
    By s27sam in forum Frame
    Last Post: 08-07-2009, 04:54 PM
  5. Cutting stainless steel sheet
    By tooltime in forum Shop Talk
    Last Post: 03-05-2008, 12:10 AM
