Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
    Re: Cutting internal keyways
    western ky
    Everything you ever wanted to know about broaching a keyway, just don't bang your broach on your workbench like the guy in the video......
    BROACHING A KEYWAY IN A PULLEY tubalcain - YouTube
    Senior Member fatal-exception's Avatar
    Nov 2009
    Saskatchewan, Canada
    In a pinch you can mount a square tool blank in the tool holder of your lathe and use the compound slide to broach the keyway. Of course, you will have to grind the right geometry on the broaching tool for it to work.
    It might be hard on a mini lathe though...
    Tubalcain has some great machining vids on Youtube. Every wannabe machinist should watch.
    Sep 2006
    Groves, Texas
    This is some great information, thanks, very useful. Its much more accurate than the way i did a pulley for my wood lath, i used three hacksaw blades on my hacksaw then cleaned up with hand file, been using for two years now and no problems yet...
    western ky
    I think he said he started out trying to cut a key with his Lathe saddle. It works, but you need a solid setup and it does as much scrapping as it does cutting.
    I've seen dedicated linear slides built that held a ground bit and bolted in place of the tool post.
    A Chinese broach set is dirt cheap and considerably faster. You just need an Arbor press tall enough for your needs....
    Moving the bed back and forth works but its slow. I've been doing a little bit each day and I'm about .10 deep I need to be at .12.
    western ky
    This is an example of a linear slide I was talking about. Faster than moving the carriage, but ........
    Dog Rough Key Way Slotter
    Nov 2009
    I designed one similar to that after reading that thread a year ago. I got all the pieces made, just need to put it together.
    Madmodder is another informative forum general machining. Some pretty neat projects on there too.
    Are you a member of that site vidio1?
    Paul
    western ky
    Quote Originally Posted by fatal-exception View Post
    Paul
    Yeah, and a few others. Mostly about metal working and machining but occasionally I visit a Robotics or electronics site....
  1. internal grooving tool
    By Stomper in forum Shop Talk
    Last Post: 08-28-2011, 08:18 PM
  2. Plasma Cutting Brake Rotor?
    By rgvkid in forum Driveline
    Last Post: 03-04-2011, 04:29 PM
  3. cutting and rewelding tubing
    By s27sam in forum Frame
    Last Post: 08-07-2009, 04:54 PM
  4. Cutting Keyways
    By JimmieD in forum Shop Talk
    Last Post: 04-13-2009, 08:54 PM
  5. Cutting stainless steel sheet
    By tooltime in forum Shop Talk
    Last Post: 03-05-2008, 12:10 AM
