Results 1 to 3 of 3
    aftermarket expansion chambers
    I suggest you check your expansion chambers for rust. The ones I have have a separate head pipe about 10 inches long that attaches to the main body of the pipe behind the seat. The collars (for lack of a better term) that align the two pieces have rusted and one fell apart, and the other is on it's way to failure. I'm trying to decide if repair or replacement is the way to go. Any thoughts about welding (or brazing) the two sections together to make a one piece pipe?
    I race, therefore I am
    Re: aftermarket expansion chambers
    Blog Entries
    1
    If you can still get them in and out as a 1 piece unit I would totally weld them up. Just make sure the pipe is rubber mounted in case the slip joint was also meant to be a flex joint........
    Yeah, they come out as one. I hadn't thought about the joint for flex. Thanks!
  1. Aftermarket car wheels on buggy
    By mjl30 in forum Suspension - Wheels & Tires
    Last Post: 03-27-2016, 12:29 AM
  2. Aftermarket Alternator Kit
    By JD66 in forum Controls and electrical
    Last Post: 12-17-2014, 12:17 PM
  3. Aftermarket external oil cooler
    By GateKeeper in forum Cooling
    Last Post: 02-14-2014, 05:54 AM
  4. radiator stock or aftermarket
    By GrossGraphix in forum Cooling
    Last Post: 12-11-2012, 10:51 PM
  5. Od-Mods Website expansion. Help wanted!
    By FL250Modder in forum Honda's Pilot & Odyssey
    Last Post: 01-29-2008, 11:58 AM
