Results 1 to 5 of 5
    FL400 CR500 motorswap
    Senior Member fns's Avatar
    Apr 2012
    phoenix az
    I am looking for information about upgrading my niece's buggy. Please keep in mind she probably will never get over 130lbs. She blew up her FL400 this weekend at the dunes. It leaned out and popped the piston and took out the cylinder.
    I was thinking going to CR500? Any information would be appreciated. (Like what does it take to do)
    Thanks
    Re: FL400 CR500 motorswap
    You're thinking about using a CR500 cylinder jug/Head on the FL400 bottom end?
    Apr 2012
    phoenix az
    I am not sure if it is a direct fit? If I can bolt a CR500 jug/head/piston/intake/carb that would be easy. But I am not sure if I have to replace the rod or crank? I know I have seen in the past people talk about putting cr500 in these Pilots. I need to do figure something out quick. We have a dunes trip planned in 3 weeks.
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    Contact me - I may know where there's a fully ready to drop in CR500 converted FL400 motor for sale.
    You have to do quite a bit to the cases - weld in some stuff, move the studs, modify the ports, bore the cases so the piston doesn't hit the top of them, etc., etc..
  1. Fl400 belts
    By azpilot in forum Honda's Pilot & Odyssey
    Last Post: 11-23-2013, 08:55 PM
  2. CR500 cool converson
    By Rat4020 in forum MiniBuggy.net Lounge!
    Last Post: 02-14-2013, 01:10 PM
  3. FL400 fnr axle
    By Less4more in forum Honda's Pilot & Odyssey
    Last Post: 02-14-2010, 04:09 AM
  4. Our SV1 Duner motorswap kit.....
    By CBRhino in forum The UTV Area
    Last Post: 01-30-2010, 11:33 AM
  5. Pilot with CR500 conversion EGT Temps
    By Odyknuck in forum Honda's Pilot & Odyssey
    Last Post: 07-21-2008, 10:59 AM
