Results 1 to 3 of 3
    FL250 front/rear hub question?
    Member outtakontroll's Avatar
    Oct 2009
    SW Pennsylvania
    I had came across some info about old 99 400ex rear hubs fitting the fl250's. Here FL250 hubs
    It says $21.80 each. From bikebandit dot com they want well over $100 ea for the rear hubs.
    Does anyone else know if any other hubs will fit the fl250?
    Also I read this article:
    Suspension Tips:
    The front hubs (drums) from a FL350 Odyssey and the old Honda Fourtrax will fit your FL250 if you would like
    to change the front bolt pattern from 3 on 100mm to a 4 on 110mm bolt pattern. I got mine at a salvage yard for
    $20. This will allow you to purchase front wheels in 8" or 10" diameter with pretty well any offset & width you
    want to run. The aftermarket 3 on 100 wheels are very limited for sizes/offsets/widths nowadays (lately they
    can only be ordered 8"diameter 6" width with no offset as far as I know). The 350 drums are aluminum, the
    fourtrax are steel, so the 350's are lighter. I usually cut the drum surface off so it is just a hub. I am sure there
    are other Honda hubs that will work, but these I know will work. If you have 4 on 110 mm front hubs & ride with
    350's much you can borrow a spare tire from them if you get a flat & don't have a front spare handy. Also the
    FL350 Odyssey/Honda Fourtrax hubs come with sealed bearings and that is good for riding in the mud.
    Does anyone know what year Fourtrax the front hubs will work from?
    Or are there other make and models that will work for the front/rear etc?
    Also about the last part about the mud.
    Do these things go ok in the mud? Being that they have an open belt which I figured would be bad for water/mud making the belt slip and leaving you to burn the belt off.
    Is that not the case with these machines? Has anyone had any experience in the water/mud without the belt slipping like crazy?
    Thanks in advance !
    Any help would be greatly appreciated ! ! !
    Thanks in advance.
    He who dies with the most toys wins ! But still Dies !
    My machines:
    2001 Polaris Scrambler 500 2x4
    1978 Honda Odyssey FL250
    Honda FL350 2seater
    1985 Honda FL350R with a 340 Kawasaki sled engine
    Re: FL250 front/rear hub question?
    mud + odyssey =FUN
    i burried mine up to the frame rails and got stuck and had to be pulled out my my brothers roketa
    it wouldnt start after that for like 30 minutes so make sure you go to the local auto or 4x4 store and get some wire/electrical drying spray stuff.
    about the belt thats probably why i got stuck but belts are only like 35 bucks right?
    so if you do burn one its worth it in my opinion
    TRX125 FourTrax (85 & 86)
    TRX200 FourTrax (90 & 91)
    TRX200D FourTrax Type II (90-97)
    TRX200SX FourTrax (86-88)
    TRX250 FourTrax (85-87)
    TRX300 FourTrax (88-01)
    TRX300FW FourTrax 4x4 (88-01)
    TRX350 FourTrax 4x4 (86 & 87)
    TRX350D FourTrax Foreman 4x4 (87-89)
    TRX350FE FourTrax Rancher 4x4 (00-03)
    TRX350FM FourTrax Rancher (00 & 01)
    TRX350FM FourTrax Rancher 4x4 (00-03)
    TRX350TE FourTrax Rancher ES (00-03)
    TRX350TM FourTrax Rancher (02 & 03)
    TRX400FM FourTrax Foreman (95-02)
    TRX400FW FourTrax Foreman 4x4 (95-02)
    TRX450E FourTrax Foreman (98-02)
    TRX450ES FourTrax Foreman (98-02)
    TRX450FE FourTrax Foreman ES 4 (02)
    TRX450FM FourTrax Foreman S 4x (02)
    TRX450S FourTrax Foreman (98-00)
    TRX500FA FourTrax Foreman Rubi (00-02)
  1. 78 fl250 front shock question?
    By outtakontroll in forum Honda's Pilot & Odyssey
    Last Post: 10-14-2009, 01:13 AM
  2. custom fl250 bumper question
    By fl250driver in forum Honda's Pilot & Odyssey
    Last Post: 10-07-2009, 11:16 AM
  3. exhust question
    By 455bird in forum Motor - Engine
    Last Post: 05-09-2009, 09:36 AM
  4. Quick question about trailing arms
    By andy777bmx in forum Suspension - Wheels & Tires
    Last Post: 01-22-2009, 07:32 PM
