Results 1 to 8 of 8
    Big & Tall drivers
    Hi all - any of you guys who are tall and/or bigger have suggestions to make riding the FL350 more comfortable? I'm 6'2" and a solid guy and its pretty tight. OEM seat is all the way back. I heard about aftermarket seats giving some leg room but no details.
    Any tips from similar drivers?
    Re: Big & Tall drivers
    Sep 2014
    West Palm Beach FL
    I know the purest wont like my suggestion but you could cut it in half and make it longer.
    Jan 2015
    Norco, CA
    I would think aftermarket seats would be bigger and actually hinder leg room
    Lansing, MI
    The Kirky dirt track seat may create more space, but at the expense of comfort. Have you taken out the rubber pad out at the very front of the foot well? That will give an inch of foot room.
    I race, therefore I am
    I haven't taken that pad out yet. I'm new to the Odyssey, I just got it a couple weeks ago and havent had much time to tinker with it. I will definitely remove that pad and see how much that helps.
    I also heard the Kirkey seat, sits more upright and your back straighter up giving another couple inches of leg room. I'll look into it.
    Thanks!
    Sep 2014
    West Palm Beach FL
    Sitting up straighter could create head space issues.
    S.W. Michigan
    like Ody said,,,,Kirkey racing seats can gain you quite a bit more room, depending on which seats you are comparing to.
    I was comparing seats in one of our builds and it gained 3" head room and 2" leg room compared to the other seat I was testing
    this is one that we use
    Kirkey seats
    you can buy mounts, or make mounts to set it at your desired lay back angle
    I run the padded seat cover, which I think is quite comfortable
    seat cover
    Senior Member turbomike9's Avatar
    Oct 2014
    WI
    Is the Pilot seat thicker than the Ody? I have seen guys put Pilot seats in 350's. I'm sure it wont help your situation, was just curious because I'm 6'3"
    Edge Piranha with Sled Engine, 2 Margay sprint race karts, and a couple of fun Karts
  1. Drivers in the Indy 500 and Racing Dreamz
    By RacingDreamz in forum MiniBuggy.net Lounge!
    Last Post: 05-27-2012, 03:34 PM
  2. ST4 driver's legspace...
    By Binze in forum ST4
    Last Post: 12-23-2011, 08:27 PM
  3. Steering rack questions for the experienced drivers
    By intfit in forum Suspension - Wheels & Tires
    Last Post: 08-06-2010, 07:19 AM
  4. OOOOOPS! Fun with drivers
    By nutz4sand in forum MiniBuggy.net Lounge!
    Last Post: 11-03-2009, 02:28 PM
