Thread: Bent Front Beam
Results 1 to 10 of 19
    Bent Front Beam
    Member Mississippian's Avatar
    Jan 2016
    North East Mississippi
    The front beam/axle is bent on the 1980 odyssey I purchased. Anyone straightened one before and what did you do to get it straight?
    Re: Bent Front Beam
    Jun 2014
    Upper Peninsula, MI
    I've straightened the jackshaft on my little buggy before with just a press and an indicator
    Re: Bent Front Beam
    Lansing, MI
    I've never done it to a 250, but on my 350, we put a long large pipe over the stub axle while applying heat, then used the pipe to bend it back. It took a lot of force to get it back in line.
    I race, therefore I am
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    Which side?
    I have a frame and the one looks bent but the other (left while sitting in it) looks ok.
    Not going to be using them.
    Re: Bent Front Beam
    Jan 2016
    I was thinking on finding a pipe that would fit inside the tube. Insert the pipe and heat the beam with a torch. As the beam straightened, I would slide the pipe up inside of the beam until it went in about half way. It should be straight then.
    MASCMAN, are you saying you have an FL250 frame to sale or give away?
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    If you are talking about the j-arm, I can help you...I have a project that I bought but won't be using the Odyssey frame. It has been grafted onto behind the seat area.
    Looks like it has different front hubs...maybe from something with front drums?
    I thought about using the frame but not sure yet, but I am doing my own suspension.
    Re: Bent Front Beam
    Jan 2016
    That's what I am trying to do. Convert the three bolt hubs to something else with four bolt hubs . I can't figure out what will fit. Any idea of what the hubs came off of?
    I am also thinking of some type of rear suspension, probably a trailing arm type.
    Do you have a list of parts from other ATV's that fit the FL250?
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    Quote Originally Posted by Mississippian View Post
    That is what I was going to do to my frame but have decided to just build one!
    Here are some pics...I may be able to get some of the hubs later. If you are interested I am not going to use them.
    ODDY Project by mascman | Photobucket
    Re: Bent Front Beam
    Jan 2016
    What type of engine is that? That is cool, wish I could find one out this way.
    I was considering getting a second frame to cut and use as the rear swing arm.
    It would extend the frame about 4-6 inches. Ody parts are hard to find in my area.
    I found a wiring harness on Craigslist to convent to Ody from points to CDI for $20 including shipping.
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    Basically I am stealing the cage, motor and probably the steering wheel...anything else us is up for grabs.
  1. Front modular clips
    By ProtoDie in forum ProtoDie Buggy Group
    Last Post: 06-24-2015, 05:12 PM
  2. front engine chassis
    By tedsfab in forum MiniBuggy.net Lounge!
    Last Post: 06-23-2014, 11:31 PM
  3. Front Wheel kits - front brake lines
    Last Post: 04-24-2014, 09:32 AM
  4. New Front End, longer wheel base & Video of testing.
    Last Post: 08-16-2009, 08:37 PM
  5. Front Wheel Alignment For Off Road Kart
    By BigD in forum Suspension - Wheels & Tires
    Last Post: 03-22-2006, 09:21 PM
