Results 11 to 20 of 29
    S.W. Michigan
    LOL, yes, that would keep me busy.
    Sep 2005
    Pacific Northwest
    Nice job Proto. Tim
    Sep 2005
    Pacific Northwest
    Proto ... What radiator are you using? Thx Tim
    Feb 2006
    Winder Georgia
    there is one on here for about 225.00 i think.
    http://www.hyperracing.com/
    S.W. Michigan
    Yes, Hyper racing sells it. $259
    The radiator is made by Saldana Racing products.
    I really like it, and we have not had any heat issues.
    Sep 2005
    Pacific Northwest
    Thx guys. Tim
    sweet ride proto
    cadillac, michigan
    nice package there proto. looks like i'm following a bit in your footsteps on my far simpler project.
    anyone out there have some suggestions on where i can research the guts of such a rear drive? i have a v-twin chain drive motor for this job. i'd hate to not go with a cv joint and disk brake setup.
    rear drive info
    S.W. Michigan
    Welcome to the site.
    The rear drive is 1 3/8 6 splined shaft, 924 cv's. I machined up the cv flange mounts , one of which is also the sprocket hub mount . These are bolted to the ends of the center shaft.
    The bearing retainers in the pics have been changed out due to failure. I have new bearings and retainers that I machined on the CNC mill. These have been holding up well.
    The rear wheel assembly is laser cut 1/4 steel welded together and then the bearing retainers are thru bolted to it.
    Brakes are Wilwood dual piston.
    S.W. Michigan
    here are the new bearing retainers
    drive unit
    cadillac, michigan
    some nive stuff dude.. 'tis a shame i work so much. hard to find a couple hours to give you guys a drive-by. any chance i could next time i'm down in the GR area? i live a couple hour north and do school in big rapids 4 days a week. time will be tight for the next 4 months doing 12 on/2 off at work and school 4/5 days a week, but if you have a few mins i'd love to take advantage of your hospitality. didn't i read somewhere you keep your cars at the tool&die shop?
    cheers
