Page 1 of 13 1 2 3 11 ... LastLast
Results 1 to 10 of 121
    ProtoDie- ProtoLite 1000 single seat racer
    S.W. Michigan
    All right, time to start a thread on this one.
    This build is the 3rd generation of our single seat race buggy.
    Lots of time in design making tweaks, changes for improved performance and tuning. Mostly more tunable.
    This one has a few more inches of head room in the cockpit than our previous buggies.
    This is the single seat version we plan on releasing plans for after it is built & tested.
    I am building this one for a customer and it will have a 2008 GSXR 1000 in it plenty of power
    Also an RPM gear box 5.4:1 ratio
    The rear engine cradle uses the same plates as our new 2 seater, but has a narrower mounting. But pretty much the same.
    nuff talk, here are some pics
    Re: ProtoDie- ProtoLite 1000 single seat racer
    S.W. Michigan
    more pics
    S.W. Michigan
    yup,,,,,,,,,,,,,,,,,,,,,,,,more pics
    S.W. Michigan
    you guessed it,,,,,,,,,,,more pics
    Sweet stuff Jody!
    Looks like it is itching to race off the table. Love the engine cradle. I'd like to do that for my pending single seater using a CBR 1000.
    Will you be selling that as a separate component?
    S.W. Michigan
    Thanks guys
    Gene,
    Yes, we will be making the engine cradle available seperate. with a arms and rear wheel uprights
    Future pics will show how the RPM gear box is mounted in.
    Can't wait to drive this one
    Sep 2006
    New Mexico
    I like that gearbox mount. Are you gonna run a input brake on the gearbox?
    S.W. Michigan
    Thanks
    Not on the upper shaft of the gear box.
    I am making rotors that will have the same pattern as the 930 cv's.
    They will bolt between the cv & the boot.
    Down the road I may run outboard brakes at the wheels, when I go differential and street legal.
    The engine cradle plates are slotted and will have turn buckles for the RPM gear box. This can be used as a tensioner and to avoid half links when changing sprocket sizes.
    There will also be an idler sprocket chain tensioner on this. Same one we have been using for years.
    This will add a quick easy chain tension adjustment.
    Feb 2006
    Winder Georgia
    More HP more chain fatigue, dont forget that, Looks like shes pretty short as is... Car looks good, Seems to have a bit of Sinister look to it almost..
    Last Post: 08-17-2014, 11:00 PM
  2. ProtoDie 2 seat mini buggy- next build
    Last Post: 09-01-2010, 08:12 PM
  3. My First Single Seat Car
    Last Post: 10-30-2008, 11:05 PM
