Page 2 of 13 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 121
    Re: ProtoDie- ProtoLite 1000 single seat racer
    S.W. Michigan
    Yup, I am aware of short chain issues. That is the reason the RPM box is tipped back, to increase the chain length as much as possible.
    Looks like the chain will be 38" to 40" long.
    The live axle setup was 50"
    I would be curious what length chains others are running on their RPM boxes , what is the (short) length to where issues start.
    Sinister look?
    While I do think Yoshi's look bad ass and are top notch. I do not see much in common other than 4 wheels, motors,,um they are buggies?
    Other than a few mods, tweeks ,,,This is the same basic single seat design I have been building & racing and developing for years now.
    Shorter nose, taller roll cage, reverse & a bigger motor, are the real changes.
    Thanks though.
    Member David M's Avatar
    Aug 2008
    Barstow,Ca
    Looking forward to the release of the plans
    S.W. Michigan
    time for an update
    The engine went in last week, and I also received the RPM gear box.
    Seat , steering , and pedal assembly are in.
    rear arms were last night, and the front a arms will be in the next 2 days,,,then up on wheels with shocks & steering.
    should be up on wheels this week.
    then custom fuel cell, exhaust , electrical,,,,& so forth
    hope to test drive in 2 weeks
    S.W. Michigan
    more pics
    S.W. Michigan
    and a couple more
    S.W. Michigan
    Alright,,,update time
    Front & rear A arms are on
    Steering is in
    Radiator is mounted
    Rack was extended on each side by 4"
    S.W. Michigan
    more
    Sep 2006
    New Mexico
    You going to put some kind of radiator guard?
    The angles that those a-arms reach at full droop is steep! How much wheel scrub does that create?
    S.W. Michigan
    Yes, there will be a guard to protect the radiator.
    Vented Aluminum, and then a screen behind that.
    see cad pic
    Front angles are pretty much the same we have been running with no issues, maybe slightly steeper.
    Wheel scrub thru full travel is around 6"
    also pretty much the same as we have been running.
    Short front a arms on a car this size probably create more wheel scrub than a large center bulkhead car.
    How much wheel srcub on did you end up with on your new build?
    Feb 2006
    Winder Georgia
    Looks like with a little force and the bit of play in the suspension you could actually force the top of the spindle and the upper a arm in and make it lock up on itself...
  2. ProtoDie 2 seat mini buggy- next build
    Last Post: 09-01-2010, 07:12 PM
  3. My First Single Seat Car
    Last Post: 10-30-2008, 10:05 PM
