I am building a Badlands ST2 running a 05 CBR 600rr motor. I need to purchase a rear sprocket, but not sure what size to use. I wanted to run a 60 tooth rear and 14 tooth front, but was told a 72 tooth rear would be much better. My concern is the size difference in the sprokets. I want as much travel as possible and I know the larger sprocket will hang down more. Any info will be a great help.
#2 (permalink) |
I am running a 13/60 combo with my 750, and it is nice. I can take off on a level surface at idle and turn lock to lock on asphault while idling. It is a little faster than walking speed.
It mostly depends on tire size. I am running 25.5 inch OD tires but plan to go to 27's. If you are running anything near a 30, you need the 72.
I am running 28 inch tires, dirt and sand. It sounds as if the 72 will get more more bottom end power, which I know I will need. Anyone know where to get a custom sprocket cut? I need one for a 4 bolt, 115 milimeter bolt pattern, 1 3/4 inch center hub. I made a carrier out of a car hub that went to a 280Z and wanted to use its stock bolt pattern for the sprocket.
#4 (permalink) |
Go as big as you can afford for space. Even with a 72 top speed will not be an issue. The bigger the more bottom end. If you can try to drop a tooth in the front instead of going bigger in the rear. Also keep in mind that the closer the sprockets are to eachother with a large rear sprocket the less teeth will engage the chain in the front.
| sprocket size... | reddmax | Driveline | 8 | 03-14-2008 08:48 PM |
| Sprocket size need help | buggito | Driveline | 11 | 12-21-2007 02:00 AM |
| Sprocket Size ZX600E | amergin | Driveline | 10 | 05-16-2007 10:00 AM |
| Sprocket Size (input Please?) | TutTech | Driveline | 7 | 05-04-2007 01:20 PM |
| Questions About Sprockets & Jack-Shafts | Kawabuggy | Driveline | 26 | 12-31-2006 07:46 AM |
