Old 08-18-2008, 03:36 PM   #21 (permalink)
Default Re: F150 Outer Bearing Hubs and CV's
If the axles are the proper length, why would you need a clip to keep them from mushrooming the ends? It shouldn't be long enough to put pressure on the ends right?
Old 08-18-2008, 05:33 PM   #22 (permalink)
masterfabr's Avatar
Hammer effect.
Old 08-18-2008, 09:14 PM   #23 (permalink)
LockedupXJ's Avatar
So do Chevy bearing hubs accept 930 axles also??
LockedupXJ is offline   Reply With Quote
Old 08-18-2008, 09:19 PM   #24 (permalink)
If you use a custom stub axle it will. Now whether it fits inside a chevy outer CV is another question. Custom stub axles are quite pricy. Fitting it into a stock outer CV is the idea of this thread because it eliminates all that cost in favor of off the shelf components.
Old 08-19-2008, 12:28 AM   #25 (permalink)
LockedupXJ's Avatar
Sorry thats what i meant in my question. Will the 930 axle fit in the chevy CV say a S-10 Hub and front CV.
Old 08-19-2008, 12:39 AM   #26 (permalink)
Bugpac's Avatar
the chevy cv is not 28 spline "930"...I believe they are 27...
Old 08-19-2008, 12:40 AM   #27 (permalink)
Bugpac's Avatar
I misread the questinon as well, 930 stubs do not fit s-10 axles, unless you buy the micros stubs,"cant remebr who sells them" some guys sell the 27 spline, but most are 33 spline like dans sells etc....
Old 08-19-2008, 05:10 AM   #28 (permalink)
bdkw1's Avatar
The 33 spline Chevy 1500? CV's are the same as 934CV's. The 2500? 35 spline are the same as a 934.5CV.
Old 08-19-2008, 11:08 AM   #29 (permalink)
Bugpac's Avatar
we never did figure it out entirely, it seems like the 1500 was 31 spline, cant rember now, seems like 3/4 ton chevy was the 33, but they have 6 lugs....Not the 5 on 4.75 that everyone sells...we came to the end conclusion empi had there stubs made and there bearing assemblys custom made for the sake of monopoly...
Old 08-19-2008, 11:45 PM   #30 (permalink)
LockedupXJ's Avatar
What do Empi's stubs and bearings go for $ wise? I found them on there site but i cant find a price for them
