Old 07-03-2008, 03:16 AM   #1 (permalink)
Default 6 Part Forward Reverse Gearbox
I just dissasembled the gearbox on my kids mini mini buggy. I used a FNR gearbox from a lawnmower on a fully caged gokart frame with 21" atv tires. It is a Spicer gearbox. It amazed me how simple it is. The input shaft is a pinion shaft. 90 degree from it is the output shaft. On each side of the pinion shaft is a ring gear. In between the ring gears is a coupler that is keyed to the shaft. It has notches that engage the ring gears for forward and reverse. I think I recall this is the same setup used on outboard motors. The gearbox is packed in grease. It is about to give up, when it does, I will clean it up and take pictures. Tim
tooltime is offline   Reply With Quote
Reverse Differential For Sale sandandsun For Sale 3 07-10-2008 06:32 PM
Reverse gearbox Help Chase044 Driveline 36 01-12-2008 12:26 AM
Forward & Reverse box greenhorn Driveline 1 02-14-2007 06:19 AM
cheap forward/ reverse LEE1969GB Driveline 2 01-26-2007 03:33 PM
snowmobile forward - reverse tranny set up ces448 Show off your toys in here! 7 01-07-2007 07:55 AM
