Old 05-27-2006, 02:52 AM   #1 (permalink)
Default Electric Reverse
Hey guys,
Im looking at adding an electric reverse to my single seater. What starters have people used and ring gears to suit (flex plate).
I like the way yoshi has his setup, anyone know what starter he has used?
Thanks
gordy is offline   Reply With Quote
Old 05-30-2006, 06:09 AM   #2 (permalink)
yoshi's Avatar
Default Re: Electric Reverse
Originally Posted by gordy
Hey guys,
Thanks
Gear reduction starter for a chrysler and a 14 inch diameter flywheel wheel off a chevy with the same teeth. I can give you the Oreilly part numbers if you wish........
www.sinistersandsports.com
Old 05-30-2006, 12:47 PM   #3 (permalink)
Thanks yoshi, Im in Australia so part numbers arent much use, but there might be other (US based) people who have use for them?
Can you tell me how does it perform torque wise? has it ever failed?
What sort of crysler (V8 or V6) Im guessing the stater is probably something around 1.5Kw.
Thanks for your help.
Old 05-30-2006, 02:37 PM   #4 (permalink)
yoshi's Avatar
I don't know all the specifics. I bought it 2 years ago. I know that chryslers have high compresion motors so the gear reduction starter they use has to be strong. I'm sure any decent gear reduction starter will work fine for your application. The place I bought mine has a lifetime warranty so if it ever fails I can trade it in for another one, free of charge. I haven't had any problems in 2 years. I would reccomend a better gear ratio than 6:1 though, It worked good but I could tell it was stressing it when I used it. It also drives pretty quick in reverse so another ratio would slow the speed down as well as put less strress on the motor. If you don't have the room for a bigger flywheel, run a jackshaft system so you can get the correct ratio. It is very cheap to build and very effective...
Old 05-30-2006, 10:56 PM   #5 (permalink)
Thanks yoshi, thats really helpfull.
Apparently diesel starters are a little slower than petrol and they are already high compression so im going to give that a go.
If it doesnt work out i'll try the jackshaft idea, but that would take a bit of work sourcing parts for that in australia.
Thanks for your advice.
Old 05-31-2006, 01:53 AM   #6 (permalink)
yoshi's Avatar
The jackshaft is just 2 bearing carriers instead of one, it wouldn't be hard to build at all. You can get 5 to 7 inches more travel with a jackshaft as well.....
Old 08-22-2006, 07:04 AM   #7 (permalink)
I'ld like to see this set-up.
Seems to me it would be a great set-up.
For the times I use reverse, it would be all I would need.
DuneMe is offline   Reply With Quote
Old 09-12-2006, 06:50 AM   #8 (permalink)
I would recommend a starter from a relatively new European diesel car - Peugeot, Citroen, Golf (Rabbit in the US) or similar. They're well engineered and light weight.
I'm currently thinking along these lines for a reverse for my own buggies, but I'm unsure of availability of these cars in the US. Can anyone over there comment on the popularity of these models?
Old 09-12-2006, 01:17 PM   #9 (permalink)
yoshi's Avatar
Lighter isn't necessarly better, you need a starter that is use to turning over motors with alot of compression otherwise you will burn it up. A gear reduction starter is a must, they usually aren't to big either....
Old 09-12-2006, 02:41 PM   #10 (permalink)
That's why I suggested a starter from a diesel car. Modern diesels have very high compression and the Europeans are well up with the technology.
