#372 (permalink) |
Hello Yoshi
Have you had any problems with the chains burning up using the Jeffco setup? With the small sprocket on the trans it seems like you end up with a fairly short chain. I had seen a car in the dezert who had one and added a oiling system to his car for that reason. Thanks Bob |
#373 (permalink) | |
#375 (permalink) | |
It all comes down to how long you drive the car at high speed. Take any MIDI sized car and drive it at 80-90mph for about 10 minutes straight and the chain will be gone. The only fix that I have found is putting the chain in a oil bath. A little difficult to execute but it is the only effective fix. With the gear reduction where it needs to be to move the weight of the bigger cars the chain has to be running nearly twice the feet per minute as it would on a bike. No one rides a bike at 180mph for 10 minutes so they never really see the equivalent. I think a lot of folks don't drive at higher speeds for extended periods of time in their MC powered cars so many may not have experienced the issue but I will guarantee that all midi-sized cars will have this problem if pushed in that manor. Some people may not call it a problem because they use their cars at a more moderate speed and do short winded blasts and let off and cruise for awhile, then do it again...no problem. For me it has been a BIG problem out in the open desert roads. Like I said though, oil bath has been the only thing that has fixed it for me. Some people think that a longer chain or other things will fix that problem but I don't. Giving the chain a extra millisecond to cool off doesn't seem effective to me. There needs to be a medium there besides just air to keep the chain lubed up and at a stable temperature. |
#377 (permalink) |
What do you guys think would be the best differential for a street kart? the frame is going to be wide and the a arms are going to be short. I need reverse and I need brakes on both sides of it.
#380 (permalink) |
Yes. Look up Arrowhead's old fart from florence thread. He's the lead dog with this setup.
Gearing is widely selectable. I think he leaves the Honda in 3rd but can select other gears for different conditions. Probably rock crawler to Bonneville choices. Has reverse of course. Two or three other members are doing it too. |
