Old 06-20-2006, 02:25 AM   #21 (permalink)
Just an update, I have my diff mounted in the car. The sprocket that goes on the front of the diff is from sprocket specialties, and its $62. It has no holes in it, so I can drill any holes I want to. I am going to lengthen the axles to about 30 inches (92 wide car) and I think that should be good for 20 inches travel.
headinclouds is offline   Reply With Quote
Old 06-20-2006, 02:31 AM   #22 (permalink)
the dif is 7 inches wide, and the CV pivot points are 13 inches wide. my car will have 30 inch axles and should be able to do 20 inches travel.
Old 06-20-2006, 02:34 AM   #23 (permalink)
you are not bending with that orange thing are you? like i saidd before i can bend some small stuff if you need.
Old 06-20-2006, 02:42 AM   #24 (permalink)
I really appreciate the hospitality, but its jut not realistic to do that. Im not just in need of x ammount of xxdegree bends. I need the car and bender on hand at the same time.
Yes, Im using the cheap ass bender to bend some of my pipes. So far Ive not even used it for anything on the rail. I expect 2-6 bends total from that orange thing. but it works fine so I dont see the problem even if I wanted to use it more.
Old 06-20-2006, 02:51 AM   #25 (permalink)
the trick is to fill the tubing with sand, and duck tape the ends, if you havent bent any tubing with it yet, you will see, it works great for pipe, try a scrap piece first, then go to h depot and get a bag of play sand, try to get it packed in good, tap it on the floor with one side covered. i personally have never did it this way, but i have heard a lot of people make this suggestion. 8)
Old 07-23-2006, 09:12 PM   #26 (permalink)
Jeffco is the only way to go! Cost effective and BAD A**.
Kabura
Kabura is offline   Reply With Quote
Old 07-24-2006, 01:46 AM   #27 (permalink)
Kabura
do you run one in your car ??? if you do give us a report on the goods and bad,,,, nothing is perfect
hotwheels000 is offline   Reply With Quote
Old 07-24-2006, 02:28 AM   #28 (permalink)
i have heard the roberto is the best there is, but like i say heard....
i am pretty sure you can get with a sprocket and not cvt.... 8)
Old 09-02-2006, 03:50 AM   #29 (permalink)
Send a message via Yahoo to AtvNut
The Roberto has made itself quite a name for sure
AtvNut is offline   Reply With Quote
Old 09-13-2006, 08:16 PM   #30 (permalink)
Just ran across this one
http://www.allensperformance.co.uk/gear ... plings.htm
