Results 1 to 10 of 11
    U Joints for Rear Half shaft Axles
    Senior Member turbomike9's Avatar
    Oct 2014
    WI
    Just bought a buggy that has u joints with sliding square shaft for plunge.
    The U joints are all torn up, must not be able to handle the power.
    What size/series u joints are people using? Buggy has a 100hp snowmobile engine with the snowmobile CVT. I'm assuming the ones on there currently are "US Series 6" Weasler parts, I will measure to confirm. I would also assume a splined sliding shaft would be better than a square one.
    Ya, CVs are better, but just looking to upgrade what's there on a budget for now as I bought it broke and want to get it driving and see how I like it before investing a lot into it.
    Edge Piranha with Sled Engine, 2 Margay sprint race karts, and a couple of fun Karts
    Re: U Joints for Rear Half shaft Axles
    Oct 2014
    WI
    Sep 2017
    Lincoln, Nebraska
    I'm also curious about this myself. I'm not sure on your axle size, however this was a setup I may use. There isn't a power limit on these that are listed, but it cannot be that bad. https://www.dennysdriveshaft.com/p20....250_key_.html
    Oct 2014
    WI
    At $10 a piece they certainly won’t last on my buggy.
    Sep 2017
    Lincoln, Nebraska
    Here's a few other's. Honestly surprised no one else has chimed in. https://www.pegasusautoracing.com/ke...dStart=U+joint
    Jun 2015
    Texas Panhandle
    Quote Originally Posted by turbomike9 View Post
    No but you're looking at budget repairs to see if you really want to invest the effort and money into the machine. At $10 a piece you can have a few spares on hand and that kind of thing is field repairable. And it's not your 100hp motor that the links aren't holding up to...the live axle is putting more strain on them than the motor is.
    I would say that the real long term solution is plunging CV's but I would probably just keep extra u-joints on hand myself and not worry about it.
    Those 1 inch bore yokes are only good for the industrial (5-16 hp) motors, been there a long time ago.
    You would need 1300 series joints as a minimum, in my opinion. The shock loading offroad plays havoc on the joints. Being made of cast material doesn't help either.
    Oct 2014
    WI
    What "series" are these Toyota u joints comparable too?
    https://www.driveshaftparts.com/inde...roduct_id=3726
    Sep 2017
    Lincoln, Nebraska
    I couldn't find an exact. But something on this list maybe of use. Are you getting custom yokes made? https://www.dennysdriveshaft.com/c97...s_by_size.html
    Sorry, been away for a while, missed your response.
    Not sure what those toyota joints are from? I would assume a Tundra would use something close enough to a 1310 or 1350, which is what most half ton trucks use. These series of sizes are Spicer/Dana standards.
    3/4 ton trucks used to be 1410, now they all run 1480 (or equivalent) I believe. There were a few people running 1480s with big motorcycle engines for a while. They seemed to hold up OK. The bigger cars ran the 1550 sizes (many moons ago, someone sold them on high angle, huge plunge driveshafts) but everyone seemed to dump them for 934 CV joints.
  1. I used RCV 930 CV joints and RCV custom axles on my buggy
    Last Post: 02-01-2015, 06:36 PM
  2. RidgeRunner half shaft replacement
    By wolverine350r in forum Ridge Runner
    Last Post: 01-31-2015, 07:45 AM
  3. cv joints and half shafts
    By thompson614 in forum Driveline
    Last Post: 05-19-2012, 07:29 AM
  4. REQ: stub axles, cv joints
    By kevlar129bp in forum File Library
    Last Post: 09-09-2009, 07:09 AM
  5. half-shaft help
    By lunatidx in forum Driveline
    Last Post: 10-15-2008, 07:15 PM
