Results 31 to 32 of 32
    Re: Chain Driven FNR Hub
    #31
    Senior Member whitedragon64's Avatar
    Oct 2008
    Perth Australia
    Took the buggy for a thrash up and down the road today a heap donuts in forward then a heap in reverse
    Then i felt the motor start to load up and then stall , All seized up in the rear no forward no neutral no reverse
    Had to unbolt the CV's and the push of shame back into the shed
    Stripped it down and found one of the planet gears seized to the shaft
    So back to the early question on here (something about using needle bearings / Bronze bushes )
    So now thats the new plan , Fit Phosphorus Bronze bushes and use Alloy Steel hardened Dowel Pins now
    #32
    Sep 2014
    West Palm Beach FL
    I suspected that might be an issue. As difficult as it may be, needle bearings and the same hardened shafts would seem to be the answer. I think bushings would be fine if they were fed oil, but I'm guessing they would fail with no oil pressure.
  1. chain driven buggy popping chain.. help
    By brooksie2113 in forum Driveline
    Last Post: 06-01-2015, 01:55 AM
  2. Anyone do a 4x4 chain driven buggy?
    By brandon1566 in forum Projects in Progress
    Last Post: 04-17-2014, 06:55 PM
  3. CV's OR CHAIN DRIVEN DRIVESHAFT???
    By FullThrottleKTM in forum Driveline
    Last Post: 04-04-2012, 09:44 PM
  4. 4x4 Chain driven
    By Binze in forum Driveline
    Last Post: 02-07-2010, 08:16 PM
  5. Chain driven trailing arm
    Last Post: 01-18-2007, 07:04 PM
