Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
    Re: Chain Driven FNR Hub
    Senior Member whitedragon64's Avatar
    Oct 2008
    Perth Australia
    Cheers Mate
    This is it in an Edge Cassette
    So the mount plate to mount plate is 130mm 3.302" these can be cut to suit larger Sprockets with different mounting/adjusting setups
    The Hub Dia is 205mm 8.070"
    The sprocket and brake disc Dia is 175mm 6.889"
    And CV hub to Hub (930CV's) is 153mm 6.024" this size can increase but not decrease
    It all worked nicely on the bench so im keen as to get it set up in barracuda and test it
    It will be filled with 80-90 gear oil and sealed with viton O rings and custom made Lip Seals
    I havernt finalised the selector rod assembly yet as It may be sprung loaded in the forward direction and a cable pulls the selector into neutral then into reverse so if the shifter happend to fail it will select forward as default
    Got about 4 weeks wait to get it in the buggy , wait is going to kill me
    Sep 2008
    Allendale MI
    WOW! Awesome! i can't wait to see it in action!
    Justin
    Nowhere near the desert.
    Oct 2008
    Perth Australia
    Just redesigning an old FNR box i built a few years ago and ran it for a while
    P1010906.JPG Its similar to the RPM box , this one here drives into a BMW diff
    The one Im working on at the moment can be used in this form ie coupled to a diff or used as a transfer case type unit .
    Also able to be Chain Driven as like the RPM's are
    It has a reduction of 1.5:1 ratio and able to run up to 65T sprocket so ratios are changed easily and cheaply by swaping sprockets , Plus using larger sprocket ,this lengthens the chain and lessens the drive chain angle all to help preserve the chain .
    so ratios up to 7.5:1 possible bit extreme (13/65 sprockets x 1.5:1 box ratio )
    I have also incorporated a Locker differential into the mix , the diff hub assembly can be removed from the case without stripping /splitting the case , so change the diff without removing the box from the car , maybe slot in a solid centre
    Flanges to std 930 CV's
    Oct 2008
    Ontario, Canada
    Amazing work as usual!!
  1. chain driven buggy popping chain.. help
    By brooksie2113 in forum Driveline
    Last Post: 06-01-2015, 12:55 AM
  2. Anyone do a 4x4 chain driven buggy?
    By brandon1566 in forum Projects in Progress
    Last Post: 04-17-2014, 05:55 PM
  3. CV's OR CHAIN DRIVEN DRIVESHAFT???
    By FullThrottleKTM in forum Driveline
    Last Post: 04-04-2012, 08:44 PM
  4. 4x4 Chain driven
    By Binze in forum Driveline
    Last Post: 02-07-2010, 07:16 PM
  5. Chain driven trailing arm
    Last Post: 01-18-2007, 06:04 PM
