Results 1 to 4 of 4
    zx14 front sprocket ?
    currently have a 13t front and 66t -530 rear sprocket on my buggy (found a broken front tooth) is why the gear change, just bought a 15t and 72T -530. I changed because I didn't want the chain to roll that tight in the front, and hopefully less wear on the trans; etc, contemplating a 14t front, curious on some feedback for front sprocket sizing, or if you think anything smaller than 15t is too risky?. and also if anyone knows if a zx12r sprocket fits a zx14? running about 33" extreme paddle tires
    Re: zx14 front sprocket ?
    zx12 here. Run 14/74. 12 uses diff countershaft than most, old 1000 zx size I think. But I get mine from http://www.rossonracing.com/store/in...0qunqd3i1b61m2 They can have any size made up for ya.
    Jan 2015
    Norco, CA
    72 and 74 tooth sprocket must be like having a third wheel
    Sep 2005
    Pacific Northwest
    I ran a 14 tooth counter sprocket on one of my buggies for a couple of years. I put a lot of use on it with that set up and only had to change the chain once due to wear. I totally wore out 2 rear sprockets back then and that didn't help the chain life for sure. Ultimately I wanted higher gearing on that buggy so I put a 15 tooth sprocket up front and have had that on there for maybe 5 years. I have also had to change the chain once due to wear with that set up. I went to a hardened rear sprocket and it has held up fine.
  1. 2005 GSXR 750 Front Sprocket for 530 Chain
    By thenxtEMIG in forum Driveline
    Last Post: 06-03-2016, 11:50 PM
  2. WTB 24 tooth 530 pitch front sprocket
    By bngcustoms in forum For Sale
    Last Post: 03-10-2014, 01:13 PM
  3. How to offset front sprocket
    By trunknuts in forum Driveline
    Last Post: 01-20-2012, 12:49 PM
  4. 630 front sprocket ?
    By hermie in forum Driveline
    Last Post: 07-07-2010, 09:07 PM
  5. Can't find a 630 18t sprocket for ZX14 , any help?
    By standfast in forum Motor - Engine
    Last Post: 03-17-2009, 03:05 PM
