Results 1 to 3 of 3
    reverse driven through tensionor sprocket
    I am building a buggy powered by a 600 gsxr and I'm considering options for reverse. My thought is to run a 12 tooth sprocket connected to a shaft ran through a bearing-ed housing on an adjustable swing arm as a chain tensor. On the opposite end of this shaft I will connect a gear with the same pitch as my starter motor and just large enough to give enough clearance between the body of the starter and the shaft housing (2-3 inches). The starter will be mounted to the tension swing arm. Seems like this will work as long as I make everything robust enough. Has anyone ever tried this? Any down sides I may be missing?
    Re: reverse driven through tensionor sprocket
    A sprag bearing in the idler would keep everything from rotating when not in use.
    I had all of the parts to do this at one time. Sold everything when i sold the buggy. I think I had a reverse rotation starter so i could tuck it right behind the motor. It would stick out from the side otherwise.
    The starter gear was a 10 pitch, I believe it was from a Chrysler of some sort, it was gear reduction but reverse rotation. Gears are easy to get to match as well. I was going to use the bendix in the starter to keep it from engaging.
  1. Reverse sprocket gear
    By Turtle in forum Driveline
    Last Post: 05-24-2017, 09:28 PM
  2. DXF's of revrse sprocket & 60T 530 sprocket
    By grga88 in forum The Drawing Room
    Last Post: 09-02-2012, 08:24 AM
  3. Sled Driven and driven clutch alignment
    By Jay1823 in forum Motor - Engine
    Last Post: 06-28-2011, 07:24 PM
  4. Powertech LSD diff/reverse Chain driven
    By rutiz in forum Driveline
    Last Post: 04-18-2009, 11:03 AM
  5. Driven clutch help
    By nutnbolt2002 in forum Driveline
    Last Post: 01-08-2009, 07:56 PM
