Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 46 of 46
    Re: Differential carrier turned fnr
    #41
    Jul 2014
    Des Moines Iowa
    20180307_130647.jpgthread revival! so I had to put off the build but im back at the drawing board and have figured out a better way to achieve my 4wd buggy. first to address why i cant go with an rpm diff is because even if i turned it sideways to supply power to the front and rear differential i cant get the right gearing because the lowest gearing you can get from an rpm is 3.9:1 and the lowest differential i can find for my front and rear diffs is like 2.73. And when you combine those gear ratios its way too low of gearing to have fun with other than crawling. so im back to the differential being used as an fnr but im changing the concept so that there is only a sprocket and chain going to the driveshaft going to the front diff. all my differentials will be locking diffs. so lock the fnr diff and buggy goes forward. unlock the fnr diff and lock the pinion gear and buggy goes in reverse. simple and effective. gearing can be changed by sprocket change.
    #42
    In your scenario, only the rear output would go into reverse. The front DS has the chain to it and will always go forward.
    #43
    Jul 2014
    Des Moines Iowa
    Correct. There will be a driveshaft disconnect to disengage the front diff for reverse and two wheel drive. Hopefully I don't need 4wd to reverse.
    #44
    Quote Originally Posted by mjl30 View Post
    You know by saying that the first time you need to back up you will get stuck!
    #45
    The front diff's on Rodeo's have a nice disconnect unit on them.
    #46
    Jul 2014
    Des Moines Iowa
    Quote Originally Posted by ODB View Post
    Dang it you're right lol! But hey if you ain't pushing it to the limits you ain't doing it right!!
  1. Why is registration turned off
    By jersdunz in forum MiniBuggy.net Lounge!
    Last Post: 07-16-2015, 04:09 PM
  2. differential
    By hackncut in forum Asphalt Runners
    Last Post: 08-23-2013, 11:21 PM
  3. Differential
    By Marrow in forum Driveline
    Last Post: 02-03-2011, 05:26 PM
  4. Another lurk turned member
    By malder in forum The Welcome Mat
    Last Post: 01-15-2008, 10:08 PM
  5. Subaru Differential
    By SeufererMotorsports in forum Driveline
    Last Post: 10-27-2007, 10:06 AM
