Go Back   MiniBuggy.Net: The Ultimate Off-Road Buggy Community > :::Fabrication::: > Driveline
Old 12-21-2012, 03:51 PM   #1 (permalink)
Default Can a # 40 sprocket work with a 420 chain
I need to replace a couple #420 sprockets that have a 1" bore but I am having a hard time finding 420 sprockets. I can find all kinds of # 40 sprockets. My question is, can a # 40 sprocket work with a #420 chain ? If this works it would help out alot. Making it easier to find a couple of sprockets. I 'm looking for a # 40 with 13 teeth x 1" bore.
Thanks for any help,
alan0043 is offline   Reply With Quote
Old 12-21-2012, 04:11 PM   #2 (permalink)
gvouvakos's Avatar
Default Re: Can a 40 t sprocket work with a 420 chain
??? "40 t " means 40 teeth.. if the pitch of the sprocket is 420 then a 420 chain will work
I am building the Badlands ST3
http://www.minibuggy.net/forum/badla...st3-build.html
gvouvakos is offline   Reply With Quote
Old 12-21-2012, 05:19 PM   #3 (permalink)
I made a mistake my using 40 t for the sprocket The sprocket does not have 40 teeth. I should have said a # 40 sprocket with 13 teeth. I will edit my first post so I do not give the wrong idea of what I'm looking for.
Thanks for the heads up,
Old 12-21-2012, 05:23 PM   #4 (permalink)
gvouvakos's Avatar
a #40 sprocket will not work with 420 chain. The sprocket is too thick
Notes on Sprockets and Chains
Old 12-21-2012, 05:32 PM   #5 (permalink)
Thanks for the help and the info.
Old 12-21-2012, 11:11 PM   #6 (permalink)
psychoholic's Avatar
Default Re: Can a # 40 sprocket work with a 420 chain
a #41 chain sprocket is narrower than the 40. Still 1/2" Pitch. 41 chain is 1/4" Wide between sidebars and #40 is 5/16". I only sell Industrial chains so I dont know what the specs are on 420 Chain.
psychoholic is offline   Reply With Quote
DXF's of revrse sprocket & 60T 530 sprocket grga88 The Drawing Room 0 09-02-2012 03:24 PM
chain heat and sprocket wear herman pahls Driveline 10 01-28-2011 02:51 AM
Sprocket? banditbuggy145 Driveline 2 09-19-2010 02:07 PM
Metric And Standard Sprockets? 530 chain work on both? rootcory Driveline 4 04-17-2010 03:19 AM
530 chain maufacture for haybusa power minibuggy??? bngcustoms MiniBuggy.net Lounge! 6 12-23-2007 06:30 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
