Results 1 to 2 of 2
    Plasma Cutting Brake Rotor?
    Jan 2009
    Los Angeles
    My Buddy has an X Y Axis Plasma Cutting table. I can give him the file for a Rotor and he can cut it out no problem. I know most rotors are made of A36 steel, but i think they are generally water jetted. Would cutting a 5/16 Rotor warp if cut by Plasma?
    Re: Plasma Cutting Brake Rotor?
    Sep 2008
    Allendale MI
    I cut mine on our waterjet, and the cutting process in general didn't warp the rotor, it was the steel stock itself. As we cut more out of the sheet, it relieved it's own tension, so the plate actually would move and warp on its own...kinda wierd, but thats what it does. I just faced both sides, and they are fine. So, if you do plasma them, just face them off in the lathe...
    Nowhere near the desert.
  1. Plasma water mist secondary cutting
    By Shrapnel in forum Shop Talk
    Last Post: 12-10-2010, 11:04 AM
  2. Brake rotor and ring gear combo
    By burton880 in forum MiniBuggy.net Lounge!
    Last Post: 01-04-2010, 08:14 PM
  3. Brake rotor material
    By MXman in forum Driveline
    Last Post: 09-26-2007, 02:40 PM
  4. New Mini Buggy Rotor
    By Sonic Offroad Andy in forum Driveline
    Last Post: 05-03-2007, 04:49 AM
  5. brake rotor material
    By masterfabr in forum Motor - Engine
    Last Post: 11-11-2006, 03:45 PM
