Hi I got a quick question for all the gurus on here. I am building a buggy and I am going to have to run a chain drive forward from the motor, so I need to make some sort of a adaptor that I can attach to the drive shaft to allow it to step out past the case of the motor. My question is are motorcycle shaft splines all the same, and if are they metric splined or is there just a given standard. Hopefully someone will know something.
#2 (permalink) |
They all be different. You plan on an home made adaptor on a sprocket or a Dwarf car driveshaft adaptor?
not to sure on my plan for doing it at the momement. I know I have seen some spline extentsions on tractor supply's web site, just wasnt sure if the splines would be the same.
#4 (permalink) |
You might get lucky but most tractor splines are bigger and thicker VS bikes having more finer ones.
#5 (permalink) |
thats the thing the one on my blaster looks like a ten spline or something close to it so I was just maybe hoping since that would be the easiest solution
| Can a shaft drive work? | Bump | Motor - Engine | 13 | 10-24-2009 03:07 PM |
| shaft drive motorcycle engine | dougy_fresh | Motor - Engine | 7 | 07-10-2009 06:24 PM |
| motorcycle enine with a drive shaft | bigwaves311 | Driveline | 7 | 01-28-2009 05:48 PM |
| Direct drive motorcycle engine setup | customfab | Driveline | 7 | 10-21-2008 09:23 PM |
| Diesel Engine Project | DesertDrifter | Motor - Engine | 15 | 07-03-2008 09:31 PM |
