Old 11-01-2009, 09:26 PM   #1 (permalink)
Default center driveline
hi i am build ing a small mini buggy (odyssey)size,i have a polaris 500 scrambler drive train i am using,i bought vw bug axle stubs and cv's joints,does any one know where to get a center drive unit,i will be using atv size chain,and i would like to find a 12 spline center shaft so i can use the beetle outer drive flanges,but i still need to bolt a sprocket and brake rotor on,any help on locating parts would be very helpful,thanks guys
u2slow is offline   Reply With Quote
Old 11-01-2009, 10:11 PM   #2 (permalink)
nutz4sand's Avatar
Default Re: center driveline
You mean to say your using a Scrambler 500 tranny (and motor maybe??)
And your trying to figure out how to make a rear spool with 12 spline shaft for common VW flanges? Driven by a chain?
Sand! The only gold I need!
Old 11-01-2009, 11:40 PM   #3 (permalink)
yes i am using the complete drivetrain
Old 11-02-2009, 08:48 AM   #4 (permalink)
6x6TRex's Avatar
Your looking for one of these just with vw flanges instead of 930, right? Ask Protodie if he can make one.
6x6TRex is offline   Reply With Quote
Old 11-09-2009, 01:18 PM   #5 (permalink)
Send a message via Yahoo to justooln2
Hello to Everyone who has posted useful information on here, and just a wave to those who haven’t. I am looking to build a mini rail in the near future. I have already started to get an inventory on parts, Honda 300 front spindles, a set of Long travel chrome, (Perdy) A-arms, A Yamaha FZR600 engine, well about 3 of them, with wire harness and all parts. I have read a lot of posts on here and I am set with the plan to use the 930 axle. Like that of ProtoDie or Yoshi. How do I find the Right OAL of the splined center shaft? I have had a hell of a time getting a mental pic of how the 930 IDS on these go together, is everything custom? How do I get the sprocket and brake Rotor to mount on this? Do they have to be custom drilled for the bolt pattern on the 930 CV? Is there any chance someone could post an exploded view of a 930 IDS with labels on the parts? With some dos and don’ts. Explaining parts, patterns, anything that you may think is useful for a person who has never actually been around these machines. Thanks again for all the information I have been able to get here so far. Don L
This is a photo of what I am working with.
justooln2 is offline   Reply With Quote
Old 11-10-2009, 05:08 AM   #6 (permalink)
Admin
Gene's Avatar
Welcome to MBN!
If you buy from Proto or Yoshi it will be pretty much turn key as far as I know. From there you can continue with design.
Gene is online now   Reply With Quote
center driveline u2slow Driveline 14 Today 04:30 AM
Swingarm pivot points off center CASH Suspension - Wheels & Tires 2 04-12-2009 01:32 AM
trailing arm help huldahq Suspension - Wheels & Tires 5 02-20-2009 02:52 AM
Center Carrier PITTduner Driveline 2 03-12-2007 02:39 AM
center hub john For Sale 1 04-24-2006 11:36 PM
