Old 10-29-2009, 02:47 PM   #11 (permalink)
LiveWire's Avatar
Default Re: cvt motor-clutch adapter problems
The radius looks small. If you switch to bolts with smaller heads, you can make the flange thicker with the bolt heads recessed. Then there will be a smaller distance from the flange surface to the clutch.
Old 10-30-2009, 01:29 AM   #12 (permalink)
I got my new adapters from Gary at Microbelmont. Wow!! what a difference in machine work and structure. I like to hear the resonance of parts and see how that relates to strength. These emit a very high pitch tight sound barely audible. Where as the other ones chimed very loud and short. I dunno. I went and tried the car on the track that I want to race on the 8th of nov. and "tested" the new part. My idea of testing something on my car is to drive the living snot out of it and see what breaks. The adapter held up great to 4 laps of serious abuse with multiple jumps and tons of banks. I stopped to give the car a once over before really going for it and noticed that the copilot tire looked bent in. Upon further investigation we discovered a bent combo stub. I guess I hit some of the corners a little to hard. I had the same issue with the drivers side stub last month. So now we ordered some new 2" hollow stubs and hubs to "upgrade" the area. I am very hopeful that my clutch adapter problems are behind me. Now lets see if I can get these parts into another country and shipped to me by next Mon. so that we can modify the uprights. Speaking of uprights. What would I need to do to my A arms to use a off the shelf upright. I have seen several available but the overall height and angle is slightly different. Would it be as simple as attaching the lower arm "as is" and then modify the upper to work out the proper arc. Or am I way off.
sorry I'm rambling
bajaBrothers is offline   Reply With Quote
Old 10-30-2009, 04:57 PM   #13 (permalink)
LiveWire's Avatar
Gary does good work. The large radius is one important improvement.
Old 10-31-2009, 12:21 AM   #14 (permalink)
Philabuster's Avatar
The frequency really does not tell you anything in relation to strength per se. All dimensions and material being equal, the higher pitch sound comes from the material with a higher hardness. Steel heat treated too hard for the application becomes brittle and not tough.
Soft materials have lower pitch sounds. If this part was made from A-2 tool steel and heat treated to 62 HRc, it would have a very high pitched sound, but it would be brittle as glass with no strength for this application.
The large radius is a nice improvement, but the sharp corners on the bottom of the counterbores for the bolt heads also induces many stress risers. If the counterbores were larger in diameter and they had a radius in the bottom, this would reduce stress in this area and still clear the bolt heads.
I'm not a mechanical engineer, but I did stay at a Holiday Inn Express last night.
Philabuster is offline   Reply With Quote
Old 10-31-2009, 01:45 AM   #15 (permalink)
Administrator
K-fab's Avatar
That one has to go down in the MBN Great Lines Hall of Fame.
Old 10-31-2009, 03:30 PM   #16 (permalink)
Thanks for the replys guys. Yeah i am by no means a mechanical engineer. Just making some observations. I think the original piece from Neil could have suffered from over hardening. Not sure though. I sent him what was left of the them so he could have them checked out.
Looks like my spuds and new hubs will be here Mon.
There will be no time to test again at the track. That should be fine just need to adjust my brake balance for the larger calipers going on in front.
Nearly New Ecotec Motor By Cbm For Sale Turn Key !, Motor, adapter plate, flywheel cl diirk For Sale 1 08-22-2009 11:03 AM
KL650 starting problems JaySea20 Motor - Engine 3 06-21-2009 03:22 AM
honda odyssey overheating problems fl250dirtslinger The Pilot & Odyssey Forum 3 10-28-2008 12:31 AM
5 on 4.5 to VW wide 5 wheel adapter? LockedupXJ Suspension - Wheels & Tires 3 07-24-2008 02:09 AM
Minirail + Bad landing = Problems Sandaholic MiniBuggy.net Lounge! 55 05-07-2006 01:20 AM
