Old 10-22-2009, 08:58 PM   #1 (permalink)
Default Mini buggy front diff
I'm building a ST4 and I'm going to make it 4x4. Was wondering what you guys thought what might fit in the front to accept CV'S yet be shaft drive to accept Honda 500 rubicon atv drive shaft? I thought about a ford 7.5 rear diff and cutting the tubes off about 4" on each side. Then making custom axles with CV adapters on the ends. Would make them for front and rear maybe. I'm way out there.Has to be strong as it will be a work horse,and hunting vechile.
Old 10-22-2009, 10:17 PM   #2 (permalink)
nutz4sand's Avatar
Default Re: Mini buggy front diff
How much power you plan to run thru it?
IRS front and rear or straight axe rear?
Shaft drive I am guessing?
How much travel you wanting?
Sand! The only gold I need!
Note to self: Be VERY "sus-pish-ush" of Voodoochickin!
If at first you DON"T succeed....DON'T take up skydiving!
Old 10-23-2009, 03:11 PM   #3 (permalink)
How about a Subaru rear diff or maybe one of these super rhino guys has pulled out the stock one for a spool. If you needed something as beefy as a 7.5, why not a T-bird 8.8? It already has a center section with flanges.
kevin quesenberry is offline   Reply With Quote
Old 10-23-2009, 04:51 PM   #4 (permalink)
Want IRS front and rear. It's the amount of HP its the amount of torque. even so the amount of HP not even 60. But when you start pulling logs out of the woods something is going to break, more in likely fron shafts.Espically the whell and tire compo I'm picking out. I'm not expecting alot of travel, maybe 14".
Old 10-23-2009, 05:20 PM   #5 (permalink)
nutz4sand's Avatar
The front end out of a older Toyota 4wd with IRS can get those numbers and a rear end out of a Toyota Supra might be found with a similair ratio (they are IRS.)
One idea I always liked was two identical car IRS diffs. Point them both forward. Then run a shaft alongside them or alongside the car. Then run an enclosed chain from the shaft to the diffs. In the back a sideways mounted motor would send power to the shaft.
Short of doing some wierd gearing BS with different size tires (not fun and two spares to carry if you go deep into the trails.) I do not know of ANY gear ratio matching front and rear IRS's one could connect VIA a common shaft right down the middle.
But the above Toyotas is where I would start to look.
Geo tracker front ends are good too but again a matching IRS rear?
Old 10-23-2009, 05:57 PM   #6 (permalink)
ErwinBnl's Avatar
Send a message via MSN to ErwinBnl
Are there chain driven differentials?
That would be ideal for my build
ErwinBnl is offline   Reply With Quote
Old 10-23-2009, 06:00 PM   #7 (permalink)
Would be nice with IRS. How would someone set it up for solid axles? Also must have a reverse. Probably should just put some ATV or UTV front and rear diff's in and make custom axles and a-arms. Do you think the Toyota diff's would be to heavy? Just thinking out loud.
Old 10-23-2009, 06:02 PM   #8 (permalink)
Is the T-bird rear end the same as the Mustangs?
Old 10-23-2009, 06:11 PM   #9 (permalink)
nutz4sand's Avatar
As far as I know the Mustangs are solid axle. A lot of the later T-birds were IRS and the diff aint to heavy. I got one here thats supposed to be out of one but I have never seen one in a scrap yard to know. Its an IRS diff from Ford and its aluminum.
I do not know the use you plan to use it for Wyatt but your comment about the wheel and tires compo (compo? ;] ) and pulling logs out of the woods would make me run nothing BUT a car diff. If its gonna be a workhorse a few extra pounds are a good thing if it holds it together.
If its a racer then its a different story.
Heavy duty and lightweight usually mean $$$$.
If you were building just a one seater and wanted 4wd for say the mud then car diffs might not be needed. But the tires size may destroy anything quad sized.
Soooo what size tires are you planning on it having?
As for a chain drive front "diff" an older Polaris 4x4 quad used to use a chain drive front setup. Ok for what it was made for but not too much more.
Old 10-23-2009, 07:14 PM   #10 (permalink)
Not sure if this is much help, but I am using two Suzuki Samurai axles for my IFS/IRS application. I am going to cut them down, re-spline them, and weld 930 flages on the outer ends. Might be an option for you.
FugginZukin is offline   Reply With Quote
MAD Mini Buggy R1 Single Seater (from RDC) elmariachi For Sale 2 02-02-2009 10:17 PM
Mini A Arm Buggy for Kids TutTech Projects in Progress 161 01-23-2009 10:15 PM
Diirks Mini Buggy TutTech Projects in Progress 54 03-25-2008 02:46 PM
mini buggy for sale Rusty Show off your toys in here! 6 11-28-2007 02:12 AM
Input Wanted for my next build. TutTech Projects in Progress 21 07-06-2007 05:07 AM
