Old 10-18-2009, 05:41 PM   #1 (permalink)
Default RPM gear change
How hard is it to change the gearing in a RPM gear box? Who could do it for me and how much? thanks
steelerman is offline   Reply With Quote
Old 10-18-2009, 07:36 PM   #2 (permalink)
ProtoDie's Avatar
Default Re: RPM gear change
It is not that hard.
Keep track of your parts,shims, or washers so you know where they go on re assembly,,,,,and be carefull of the seals and not folding them over with the shafts when putting the cover back on.
When done, make sure there is no binding, and the shaft spin freely , or like they did before the gear change
ProtoDie
Design without limits
www.protodie.com
ProtoDie is offline   Reply With Quote
Old 10-19-2009, 04:35 AM   #3 (permalink)
QuadCartel's Avatar
X2, pretty simple.
QuadCartel is offline   Reply With Quote
Old 10-19-2009, 12:59 PM   #4 (permalink)
How much are parts.
Old 10-19-2009, 01:07 PM   #5 (permalink)
Administrator
K-fab's Avatar
Parts would be the gear set - pretty much nothing else.
Contact Danno off the site or follow his stuff to his phone number and ask him.
Dan can be hard to get in touch with. Be patient and call a couple times if needed. He will respond eventually.
When you put the side plate back on, make sure that you use a good sealer.
Permatex makes a (newish product) killer sealer that comes in a squirt cheese style bottle - can't recall the particular name/number. It's a black sealer. Works beautifully.
Make sure you wipe down the mating surfaces with acetone before applying the sealing agent. You just need to put an 1/8" bead on the cast case's edge for a good seal.
BTW - Steelerman, would you edit your profile and add location?
How far are you from Cincinnati? I'd be happy to help walk you through the gear change if you're decently close and could come to my shop. I'll gladly point, grunt and guide you through the procedure.
Old 10-19-2009, 03:02 PM   #6 (permalink)
standfast's Avatar
Very easy to do just stay organized and remember what went where.
What gears do you want?
Old 10-19-2009, 07:44 PM   #7 (permalink)
Thanks K-fab, I am in central Missouri so I am a little to far. I have a Desert Dog that had a 670 Rotax, I put a new 660 turbo in it. The torque is awesome and really needs to be geared higher. I think power and torque will be similar to the RX-1, so maybe Jay can tell me where to go as far as the gearing.
Old 10-29-2009, 07:45 PM   #8 (permalink)
XRH348's Avatar
You could do yourself a digital assembly manual, take photos as you go, assembly is generally the reverse of dismantling
XRH348 is offline   Reply With Quote
Old 10-29-2009, 08:05 PM   #9 (permalink)
Administrator
K-fab's Avatar
I am waiting on a new set of gears to stick in a tranny.
I'll do a write up of how to go about changing them out when I do it.
Probably in the next week or so.
cbr gearing?? 250r05 Driveline 10 05-30-2009 12:04 AM
Change gear like Michael Schumacher! Rorty MiniBuggy.net Lounge! 7 04-25-2007 01:30 PM
Rorty Car at the dunes Video! dune Projects in Progress 19 04-10-2007 02:53 PM
Overflow from a project removal... 02RedWS6TA Projects in Progress 346 08-09-2006 08:59 PM
Golf cart axles FLATLINE_curious Projects in Progress 52 05-18-2006 05:45 PM
