Go Back   MiniBuggy.Net: The Ultimate Off-Road Buggy Community > :::Fabrication::: > Driveline
Old 08-17-2009, 05:05 AM   #1 (permalink)
Default keeping motor center in chassis with jeffco.
Hello guys i am a new to MBN and have a question. I just bought a jeffco dif and set it in my rail and noticed that i have to offset my motor to line up the sprockets . My hayabusa motor is sitting dead in the middle of my frame and know i need to off set it about 1" to the drivers side to get my axels the same lenth and line up the chain. I have read all the posts that i can find on this. I know that the jeffco was built for the busa motor what can i do to keep my motor in the center? or is everybodies motor off set to the drivers side. This is also with the sprocket slide all the way in.
brycter is offline   Reply With Quote
Old 08-17-2009, 05:13 AM   #2 (permalink)
standfast's Avatar
Default Re: keeping motor center in chassis with jeffco.
The 1" isn't gonna make much of a difference. Just mount some stuff on the opposing side to balance it out. No biggie.
Old 08-17-2009, 12:52 PM   #3 (permalink)
Administrator
K-fab's Avatar
Stand's nailed it. A small offset won't make any difference in an off road car.
Old 08-17-2009, 01:10 PM   #4 (permalink)
yoshi's Avatar
Is it 1" or 2" off center? If there is only a 1" difference from left to right, you will only move the motor a 1/2" over..........
www.sinistersandsports.com
Old 08-17-2009, 11:16 PM   #5 (permalink)
stetler's Avatar
Keep your axles the same length. Move the motor. This will help if you ever want to carry a spare axle or want to buy axles off the shelf.
What length of axles are you looking at right now?
stetler is offline   Reply With Quote
Old 08-18-2009, 04:36 AM   #6 (permalink)
26" axels.
I just thought that if a rear end was made for a motor it would be made to keep the motor center in the car. It just kind of suprized me. My RPM rear end was dead on center with the motor. How do you figure only 1/2 i have to line the motor to the rear end and that space is 1" ? I will would have to give a 1/2 with the rear end right ? How far of a offset makes a difference? The problem that i see is all my weight is on the drivers side.
Old 08-18-2009, 04:52 AM   #7 (permalink)
Admin
Gene's Avatar
I don't think it was made for the 'Busa specifically. I think case width is determined by internal components.
Even if you balance the car with components to offset the driver it will be out of whack with a passenger. Unless you are building a single seat car there will be weight bias in some way.
Old 08-18-2009, 07:01 AM   #8 (permalink)
yoshi's Avatar
Originally Posted by brycter View Post
26" axels.
I was thinking with your reverse lined up with the motor, and measuring from flange to flange to the wheels, there was a 1" difference for how long the axles would need to be, which means you need to move the motor and reverse over 1/2" to be correct, but since your talking about the sprocket off the motor being 1" away from the sprocket on the reverse (which is lined up), then yes, you would have to move it 1".....
The Jeffco unit is suppose to line up dead center I believe, but I think it's dead center for the weight balance, which means the center of the motor may not be the center for the balance point if that makes sense.
If you are dead set on leaving the motor where it's at, you can get an off center motor sprocket like the drag racers use for wider tires to make up the 1" difference, just make sure you support the motors output shaft with a bearing to help with the additional leverage....
Old 08-18-2009, 02:07 PM   #9 (permalink)
No i think i am going to move the motor but that offset sproket sounds neat. thanks guys for the info. My buddies and i have been debating this for about 2 weeks.
WTB two seat chassis or roller for dezert racing rupert14 For Sale 16 01-22-2009 07:05 AM
Wanted: Rhino or other chassis ffjosh For Sale 0 11-24-2008 02:47 PM
What to fill the chassis tubes with? Rorty Frame 32 01-06-2008 08:42 AM
General Rules and Information for our Database K-fab Class Development 12 09-20-2007 01:27 AM
How much would you pay for a rolling chassis? bajatex MiniBuggy.net Lounge! 12 03-14-2006 03:20 AM
