Old 07-01-2009, 10:51 PM   #71 (permalink)
busasandrail's Avatar
Default Re: Chain Heat Testing
But wouldnt more links equal more friction on the rollers and pins? Less rollers and pins less friction?
Old 07-01-2009, 11:06 PM   #72 (permalink)
I would think, and this is just totally guessing that more pieces would share more of the load, and work less between each piece...
Old 07-02-2009, 01:56 AM   #73 (permalink)
I think it is the relative motion between the links. For instance take your finger and press it on the desk. It doesn't heat up, but now rub it back and forth quickly a few times. I bet it gets a little warmer. Now rub it back and forth twice as many times. It gets warmer. I think it is the same with the chain. Regardless of the size of the chain, the load on it is the same, since it is limited by the torque that the engine is creating.
Old 07-02-2009, 06:11 AM   #74 (permalink)
standfast's Avatar
When the chain is engaged with the sprocket it is effected by the chordal action (polygon effect). During engagement one of the points of that polygon pushes, causing the chain to rise and then drop back down into it's engaged position. This actually causes speed variation in the chain. It slows down and speeds up at these engagement points. I think that this is where most of the heat originates. By increasing the number of teeth in the sprocket, the number of polygon points are increased and the chordal action is decreased.
Currently I am running a 16 tooth 630 which is the largest 630 I can fit due to interference with the clutch pushrod. I could fit a 20 tooth 530 chain but I suspect it would have to be dual chains to take the load.
The question is if it will be enough of a change to make a difference in the chordal action and in turn the heat generated.
I need to get this master link BS sorted it out or try to first because it is in fact our only area of issue afterall.
Old 07-02-2009, 05:13 PM   #75 (permalink)
arrowhead's Avatar
I use a heavy moly paste(molybdenum disulfide) in my masters and cv's and just a small amount in the cv's. They never leak or make a mess and I've never lost one.
But my chain fan is what saves my 36 pin 630!
Dale
Old 07-02-2009, 06:05 PM   #76 (permalink)
standfast's Avatar
Dale
I am curious what exactly the manufacturer's use for lube inside of the chain. I have read a little about it and it seems crucial to have a lubricate that maintains a good film. They talk a lot about the lube's ability to film up creating a cushion for the pin/bushing to float on.
Old 07-02-2009, 09:53 PM   #77 (permalink)
standfast's Avatar
I was talking to a chain manufacturer today about the problem at the masterlinks and he asked me if we were using a press fit master link or a slip fit. This is not referring to the rivet or clip securement it is how the sideplate actually slides onto the pins. He says a slip fit piece can create issues with o-rings ability to maintain a good seal when pushed to their limits and supposedly the press fit plates are much better. He also said that a slip fit plate will create a wink link in the chain that is up to 30% weaker in the chain and is why many people see failues there first.
Old 07-02-2009, 11:49 PM   #78 (permalink)
arrowhead's Avatar
I use a press fit and it requires a chain tool because I've tried a C clamp and vise grips but nothing works but the right tool
And a clip
I have a rivet master but I'm afraid to use it until I'm sure I can lube it properly
Old 07-03-2009, 01:49 AM   #79 (permalink)
Have you tried dry film lube? should be a coater close by, if not send me a master link
millbilly is offline   Reply With Quote
Old 07-03-2009, 03:25 AM   #80 (permalink)
Admin
Gene's Avatar
I believe that Brian King uses one piece chains and recommends to his customers that they acquire the tool (rivet master?).
I looked at the Rorty in my garage that I'm working on and this discussion ultimately should help with my project to repower from CBR1000 to a Hayabusa.
Part of the project includes lowering the RPM an inch or so and tilting it back to get a longer chain. Right now it has 24 links and that seems about 10 or 15 links short. The chain seems to not ride perfectly centered on the RPM sprocket so I'm curious to know if yours rides perfectly centered or has a slight, unavoidable favor to one side or the other.
The Chain Gotted Driveline 6 05-09-2009 05:40 AM
530 chain maufacture for haybusa power minibuggy??? bngcustoms MiniBuggy.net Lounge! 6 12-23-2007 05:30 PM
Chain at 16000 rpm LEE1969GB Driveline 13 01-20-2007 11:14 AM
