#63 (permalink) |
I use to think bigger 630 chains were better for loosing heat, but I started thinking, radiators have small fins, not big ones, so i'm thinking a smaller 530 chain will dissipate heat quicker, and (2) 530's would be stronger and prob. dissipate heat quicker than (1) 630?.........
#64 (permalink) |
2 426 or whatever number they are would be the best IMO... Rick S did the dual 4 series chains for that gixer 1000 geo car and he said after a hard run he could grab right hold of the chain...
#67 (permalink) |
more plates, more pins, less work between each piece, less heat, less fricton ...
#68 (permalink) |
Totally with Bugpac on this one, like it says on the Bosch book as well, I don't says book or theory is always right but the base of it is proven.
The problem of this is that it will need to be more tight on tolerance, the shaft need to be perfectly parallel to insure booth chain take the same load all the time even at the peak of the load, I saw my 1" shaft flexing with the sprocket just on the "side" of the bearing. To late I already got my 630 I will be glad to experiment the dual stuff.
"Anything is possible, it's just matter of Time, Money " "Always think out of the box" "Cheap is not always Better" |
#70 (permalink) |
Think of making a 6 circle out of 1 inch straight lines, then make the same 6 inch circle out of 1/2 inch lines. The angle between the 1/2 inch lines is much less (should be 50% less).
Applying that to chains would mean the chain with half the pitch would have half the angular change between links. I'm not sure that would equate to half of the heat build up, but it could be close. |
| The Chain | Gotted | Driveline | 6 | 05-09-2009 05:40 AM |
| 530 chain maufacture for haybusa power minibuggy??? | bngcustoms | MiniBuggy.net Lounge! | 6 | 12-23-2007 05:30 PM |
| Which Chain do you run? (Turbo Hayabusa 530) | DuneMe | Driveline | 20 | 02-04-2007 10:57 PM |
| Chain at 16000 rpm | LEE1969GB | Driveline | 13 | 01-20-2007 11:14 AM |
| Chain driven trailing arm | LEE1969GB | Driveline | 5 | 01-19-2007 01:04 AM |
