#52 (permalink) |
If the lube dont make it to the pins, i supose it would still keep the chain temp down somewhat. it does make a mess, but better to have a mess at the end of the race, than to not finished due to chain failure. A fan is not going to blow past the orings either. Maybee fill the luber with water or some other coolant. Just been looking on ebay, and thay now do electronic ones that spray onto the chain @ 50psi.
Is there any difference in strenth on a non o-ring chain, it seems like they have as many cons as pros. |
#53 (permalink) |
IMO a non o ring chain would handle the heat much better, they have tighter tolerances as well once the o ring chain spits the o rings out...
#55 (permalink) |
I use chain lube now because before I started using it I was wearing the sprocket teeth severely.
Since I don't have any sprocket wear and also the chain outer barrels don't get as sloppy This stuff I use goes on as a thick foam and dissipates and dries to a non sticky wax lube that the sand does not stick to at all Dale Last edited by arrowhead; 06-30-2009 at 03:43 AM. Reason: Grammar |
#57 (permalink) |
The chains come to the US from japan in huge 50' rolls. Probably not gonna get a single length chain. There aren't any US chain manuf. that make 630 chains. I am gonna order a 630 x-ring chain and give that a shot. It is on the yellow sinister car that I worked on and seems to be doing OK but it isn't driven quite as hard so it's hard to say. It has a rivet link. I need to really try to assemble it with as much lube as possible and pay attention to the final riveted width of the links to try to match it perfectly with the rest of the chain to make sure I am not pinching the rings excessively. Thats all I can come up with at this point.
#58 (permalink) |
Krause cant get a single piece chain?
#60 (permalink) |
got ya, twin 530's would take a lot of stress off one single masterlink, Cheap to try...
| The Chain | Gotted | Driveline | 6 | 05-09-2009 05:40 AM |
| 530 chain maufacture for haybusa power minibuggy??? | bngcustoms | MiniBuggy.net Lounge! | 6 | 12-23-2007 05:30 PM |
| Which Chain do you run? (Turbo Hayabusa 530) | DuneMe | Driveline | 20 | 02-04-2007 10:57 PM |
| Chain at 16000 rpm | LEE1969GB | Driveline | 13 | 01-20-2007 11:14 AM |
| Chain driven trailing arm | LEE1969GB | Driveline | 5 | 01-19-2007 01:04 AM |
