Results 1 to 5 of 5
    Reverse using Starter Motor Question
    I'm planning on adding a reverse using the tried and proven starter motor combo. Problem is, because this is an add on to an existing rail and not planned in from the beginning, I can only mount it one way.
    So I need a starter that spins counter clockwise. Can any one tell me which motors spin this direction?
    I've tried researching a lot of different ones, but haven't been able to find this info.
    Thanks
    Russ
    Re: Reverse using Starter Motor Question
    Petoskey, Michigan
    I think you may have seen these photoes before but they may be a way you can add this for reverse up out of the way?
    Also for a starter spinning counter clockwise. You talking looking at it from the bendix end?
    Most car motors spin the same direction. Old corvair flat sixes and most of the newer Honda cars all spin motors the opposite direction of most cars.
    So that might help guide you on a search for the starter you seek.
    Mounting it higher may mean having to add a couple bearings and sprockets BUT that also means you can tailor the speed some to your liking with sprocket ratios. (I have heard some say that it right on the spool makes for a fast somewhat uncontrolled backing up.) With it higher its also less likely to get damaged.
    Also consider that a small battery (like a common motorbike one) may start a small motor just fine as it was made for that. But the current required to spin a car starter and move a heavy buggy may over tax it and harm it. This can be another case to support the gear reduction mentioned above. Or swapping to a larger car battery may be needed? Just food for thought.
    BANNED renegadespec1's Avatar
    Oct 2006
    Rushcity Mn.
    That's a pretty simple fix...If you got the room...Put the starter on the other side
    Shit I forgot how to post pix
    Go Advanced Spec!
    Quote Originally Posted by renegadespec1 View Post
    Yhea, that's the problem. I actually don't have the room to flip it over. I could probably shoehorn it in between the chain (mounted to the left), but I'm not loving that idea.
    Here's a pict of the setup. I can mount the flywheel off the chainring (which looks like it'd be the easiest setup). Then I'd need the starter to mount to the right (but I need one that spins CC). I could mount the flywheel to the right of the carrier, but that'd be a ton more work to make it fit. But then again, I could use the starter as is.
  1. Controlling a starter motor for reverse
    By rahlberg13 in forum Driveline
    Last Post: 07-06-2009, 10:46 PM
  2. starter motor reverse?
    By bayou 2 in forum Driveline
    Last Post: 09-27-2008, 04:51 AM
  3. How to on starter reverse setups wanted
    By P-Dog in forum Driveline
    Last Post: 02-21-2008, 05:23 AM
  4. reversing starter for reverse
    By buggito in forum Driveline
    Last Post: 03-15-2007, 06:29 PM
