Old 02-23-2009, 01:31 AM   #21 (permalink)
Default Re: 930 drive flanges have slop!
I fixed it! Under the advice of my "drive line guy" (Border Parts in Southern California) and the same advice from RPM....I cut down the shafts to just under the width of the 930 drive flange and put a 1 3/4" washer with a grade 8 in the already threaded hole in the shaft. Now the flange is held against the shoulder of the shaft and has no "slop" in any direction. Lots of threadlock RED on the bolt and a little lock epoxy on the splines for good measure.
Now on the the next problem.....the 28 spline 26" drive shafts are too long, they hit the inside of the drive flange when horizontal from each other. Took all the distances: full compression and dropped out and 25"s are needed. I ordered a set from www.chircoestore.com they should be in next week to put the rear end back together.
Some day I will get this thing together.....oh well..... out on a busines trip this week when I get back the axles should be in. Then on to the wiring mess I found, have to start a new thread on that!
Dezzrats is offline   Reply With Quote
Explain Tripod/Tulip Drive Flanges to me Section 8 Driveline 4 08-20-2008 12:53 AM
930 CV drive flanges Tonico Driveline 1 04-18-2008 04:40 PM
Desert Dog Coyote - Test drive report. K-fab Show off your toys in here! 34 08-28-2007 11:46 PM
New 930 Drive flanges and Stub Axles --SOLD-- Kludge For Sale 5 02-09-2007 01:30 AM
taping inner drive flanges billium Driveline 18 05-19-2006 10:41 PM
