Results 1 to 7 of 7
    Guide me. Kinroad crap box?
    May 2016
    Massachusetts
    I scored this buggy real cheap. I need some direction.
    I don't know more than you see in the pics... some ideas I have are make it fast. I'm not sure what it's capable of as is but doesn't look like much. I could work with its existing engine, throw a pull start built gx200 with a tav, run a techumseh 13hp stock with electric start, or buy a 200cc lifan put the clutch on the stick and go from there. Is that 125 a gy6??? Looks a crf style engine to me.
    As for the frame is like the short wheel base. I plan on making it wider in the cock pit with bigger seats. It only has a rear brake and cheap shocks... Let's talk lol
    Re: Guide me. Kinroad crap box?
    Jun 2014
    Upper Peninsula, MI
    My build thread isn't exactly the most detailed, but I think it'd be the closest thing to what you're starting with. Mine began as a similar Chinese buggy, but I think yours is a tad smaller than mine.
    May 2016
    Massachusetts
    Quote Originally Posted by 65chedderbob View Post
    LOL wow your wheels are sick... your build is more hardcore than what I'm doing. I probably won't go that big on the engine. I have only trails and not many here in Massachusetts
    Jun 2014
    Upper Peninsula, MI
    Haha thanks, the rears are stock I think and the fronts are the same size as stock, just newer and a different tread. And yeah, the sled motor is what was laying around, so we used it and it sure scoots now lol
    May 2016
    Massachusetts
    I got it to work today. Everything functions as it should. What I like about it is it can climb and it handles good. What I dislike is its top speed. It's only a 2 speed 125cc. I'm suprised how torquey it feels for what it is but the top end is boring. I ordered a vm22 carb and thicker shorter intake manifold. I'm thinking putting a cdi in it a better spark plug and oil change. I know that won't do much but I don't think I this platform has alot of potential. 125cc is just way too small for it.
    May 2016
    Massachusetts
    I put the new carb on with the shorter manifold. The engine had a flat spot mid range. Adjusted the needle height and I'm impressed. No loss of bottom end, response is crisp top speed is improved. It was a great move for this engine. Stator seems to not be charging now. I may stay with 125cc and just upgrade to a new 3 speed. I still need a performance cdi and exhaust.
  1. 350 2 stroke kinroad sahara project
    By Dayton85 in forum Projects in Progress
    Last Post: 02-07-2014, 03:40 PM
  2. kinroad runmaster IIc
    By osiris in forum Motor - Engine
    Last Post: 04-02-2012, 09:08 AM
  3. Buggy Guide Help
    By boyerm2 in forum MiniBuggy.net Lounge!
    Last Post: 10-20-2009, 10:32 AM
  4. OHV Tire Guide
    By Dunepilot in forum Suspension - Wheels & Tires
    Last Post: 07-16-2008, 07:36 PM
  5. My first ever TIG weld.... and it's crap
    By zeroaxe in forum MiniBuggy.net Lounge!
    Last Post: 01-15-2007, 11:34 PM
