Results 1 to 10 of 11
    3D Modeling Services
    Hey Everyone,
    I would like to offer my services of 3D modeling.
    I see a lot of fabrication going on. If anything is custom machined using cnc or even manual processes, there is a good chance a 3D model or the print I can make will reduce the cost of machining. programs like MasterCam use the 3D models to generate toolpaths vs manually programming.
    Nothing in life is free! Depending on the complexity, my prices will vary. Maybe $20... maybe a few hundred or more. I will try to be as reasonable as I can. Some of you may know how expensive these programs can be. Like $8,000 expensive. I will be using SolidWorks 2012.
    I have over 7 years experience using 3D modeling software, so I can accomplish most designs. However multi-direction curves start to become difficult, like body panels. Finally, I would need dimensions and pictures of what you would like modeled.
    Additionally, I have the capability to run analysis for deflection, failure and more.
    PM me or reply if you have anything you would like to do, or if you have any questions!
    Re: 3D Modeling Services
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Where are you located?
    Hi Brody, are into offroading?
    How did you find this site?
    Any samples of your work?
    Never mind, saw your other thread.
    Sep 2011
    Northern Ohio
    Saw your other post also, Connecticut.
    Sorry guys! I found this site just generally searching for minibuggy info. Great site. I thought this was linked to my email, but apparently it is not. I am originally from NH where I bombed around on four wheelers growing up. I am into anything motorized really. I'd say I gravitate towards speed more than the rock crawling or mudding style of off roading. I use my thirdgen camaro as my fun car right now. I built just about the whole thing... sbc 383, 5-speed, S60 rear... high 12 car so it is pretty fun. I've been in CT for about a year now.
    Bullnerd, I've got plenty of samples. Sunday I will take some screenshots and post them up. I won't be able to post anything I do in my professional position, but I have some sidework I have done and college projects.
    Here are some various pictures of my work/interests.
    3D printed air cleaner(fake)
    The car
    My old K5
    Fan upgrade
    Exhaust build
    Motor
    Dimension-ed drawing
    Vice
    Class Project
    MasterCam
