The Drawing Room Discuss and share all your AUTOCAD information and ideas here. Design that perfect mini-buggy before you cut the first tube.
Old 11-03-2012, 09:48 PM   #1 (permalink)
Default FEA SW xpress help!
if i take 2 identically dimensioned straight tubes in 1010 steel and another in 4130 chromoley steel and bend them with the same force the displacement measures the same for each
this isn't correct as the 4130 has a tensile strength double that of 1010
i am using the 'light' version of xpress in SW
any help over the weekend greatly appreciated
thanks !
pabsy is offline   Reply With Quote
Old 11-05-2012, 02:38 AM   #2 (permalink)
plkracer's Avatar
Default Re: FEA SW xpress help!
Strength has nothing to do with flexibility. Most steels have approximate the same Young's modulus, (modulus of elasticity). Steel is approximately 210 GPa, while aluminum is approximately 70 GPa, therefore aluminum will bend 3 times as much with the same load. (Assuming you haven't reached the yield stress).
Be VERY careful with FEA results. Unless you are very experienced using it, don't risk your life based on the results.
Most FEA models will not account for a material yielding, so you need to check the results to make sure you are staying below the yield strength of the material. Once you reach yielding, FEA goes out the window.
Also, FEA models used in SolidWorks Xpress WILL NOT account for buckling. While a frame may look fine in FEA, it may buckle under a smaller load in real life.
