#11 (permalink) | |
Sadly I have Officially Abandoned my lonely Buggy for 2 Years and now I have the Itch and a broken dusty car.... |
#12 (permalink) | |
The idea is to try and make your shock end up 90 degrees to your arm or as close to as possible. With his current design it appears that he is going the opposite way. If left that way, you either valve the car so stiff that that suspension will not cycle well, or you will bottom out the rear quite often. There really won't be much of a medium between those. |
#13 (permalink) | |
#14 (permalink) |
Thank You,
I really appriciate the input I'm getting from you guys. Because the shocks are Emulsion type, I knew that I was going to have to get them more vertical. I will probably run a single rectangular tube for the upper rear a-arm so to give me clearance for the shock to mount to the lower a-arm (Similar to what Polaris does with its RZR S. Not sure how much torquing it will withstand though, but Cosmos should give me some decent data on that. As for the width of the rear lower a-arms.....looks like I would have to completely redesign the rear chassis, as the current configuration limits the amount of width I can seperate the mount tabs. Because the section just before the a-arms are bolted in (To allow for the engine to be mounted into the frame), I was unable to put any mount tabs along any of that section there. I may try to do a mount point up near the main roll hoop, similar to a trail arm, giving me an extra leveraging point for the rear a-arm. I was planning on using the cut brake to lock up the rear (similar to how performance atvs lock up the rear to allow me to initiate a power slide by pulling back on the handle. If I push, the cut brake will lock up the front tires, allowing me to stage and do burnouts if needed. At least that was the original thought on using the brake. I also have available a Subaru LSD rear diff that I can use if it looks like a rear diff would work better. As for the radiator, I have been playing with the idea of putting it on the rear frame spars, but the airbox for the GSXR (not drawn yet) may limit this option. I really do not want to take a "HOT" water and glycol shower if a failure occurs on the radiator. Also I would have to use an aftermarket radiator, as the stock one is not shaped well to collect enough air to effectively cool if mounted at such a steep angle. Also I really want to protect as much of the working and cooling parts of the engine of the vehicle for the eventual rollover, when and if it occurs. I would rather design the car to handle a moderate rollover, then oppose to the thinking that if it rolls I'll fix it then......not sound engineering I'm afraid. I'm glad that most of what you guys are suggesting, I've been thinking about it for a while too. It means that my reasoning is not too far off from those who know what they are talking about, and have been there already. All of your insight and expertise has greatly reduced the guess work I may make when going through this design process. True it's easier to go out and have someone build you a car, but I feel the most satisfaction comes when I can say that I built myself a offroad vehicle from conseption to completion. Nothing feels better. I'm looking forward to it all. I'll post some more angle shots so you guys can critique other areas that I might need rethinking. I really appricate everyones inputs. Cheers Edward |
#15 (permalink) |
Quik question for you guy's. Whats the reason needed for making the arms wider? Is there an equation for figuring arm width for body width, length, weight? I just want to avoid this in the future.
Thanks Chuck |
#16 (permalink) | |
The idea is to spread the load out over the frame as much as possible. Locating it all in one small area is not a good idea. |
#18 (permalink) |
Thank you guy's. So next question... When you say widen do you mean top to bottom or the actual width of the arm? Since were on the topic I figured I should ask now. Also is there something you need to keep in mind inregards to the spindle. IE.no more than twice the width of the spindle.
#19 (permalink) | |
I believe there refering to the width of the mounting points on the frame. Spread em out to distribute the load on the frame.... |
#20 (permalink) |
Again my opinion.
Its not just the width at the frame but also a triangular shape that makes them stronger.Right know you have a parralellegram.(i might be able to spell that!)
People who think they know everything,are especially annoying to those of us who do. |
| Racing Cost & Information for each Class. | TutTech | MiniBuggy.net Lounge! | 4 | 10-13-2009 04:13 PM |
| ProtoDie- ProtoLite 1000 single seat racer | ProtoDie | Projects in Progress | 111 | 09-23-2009 09:03 AM |
| Single Seat VW Suspension, Motorcycle mini buggy | TutTech | For Sale | 7 | 01-31-2009 02:39 AM |
| My First Single Seat Car | TutTech | Projects in Progress | 32 | 10-31-2008 05:05 AM |
| Design Questions - SolidWorks | BrettAB777 | Frame | 4 | 03-05-2008 04:32 PM |
