Hi I am getting ready to laser out the parts to build my trailing arms on my revised rear suspension setup.
I thought i'd stick my head in here and obtain some outside opinions on my design and what thickness you all might think i should go with. I have been considering 10 ga .135" thick and 12 ga .105" thick what are your thoughts? Here is a pdf of the arms.
Sadly I have Officially Abandoned my lonely Buggy for 2 Years and now I have the Itch and a broken dusty car.... |
#2 (permalink) | |
#3 (permalink) | |
so far. I ran the properties of the assembly in inventor and it's kicking me a figure of 38 lbs per arm at ten gauge it just seems really heavy. I wonder if a well gusseted 14 ga unit would hold up?
#4 (permalink) | |
#5 (permalink) |
Take a look at the cost of 4130 plate. It is much stronger and a dream to work with in the thin plate form and a regular Mig welds it up.
#8 (permalink) |
Needs internal support to keep it from oil canning and as bracing at the shock mounts. .100 is sufficient if braced well internally. Doesn't look like you have any camber gain though. Try to set up your welds so they are inside corner and not outside corner by running the top and bottom pieces long. You should have a way to adjust toe as well. Heims...
#9 (permalink) |
I would also suggest wrapping the outer bushing/hiem housing. They have a nasty habit of ripping out.
The bottoms will see the most abuse and should be thicker, like 8 gauge. 12 gauge is fine for the sides and top. Internal ribs can be 14 gauge. And yes, you need them. |
#10 (permalink) | |
I spent the better part of a week designing and redesigning my trailing arms just to find out they'll end up being prohibitively expensive. Needless to say I said F that. I may consider doing my arms in 1018, but I'm so totally pissed with my 10Dez (everything has been a compromise) that I'm ready to take it and throw the damn thing in the dumpster. Someone hands me $35K, comes and gets it and they can have the f'n thing. I'll be redesigning trailing arms and be using 1.25" tubing now. Why not, it's all been a compromise and a constant kick in the balls.
| Quick question about trailing arms | andy777bmx | Suspension - Wheels & Tires | 10 | 01-23-2009 02:32 AM |
| trailing arms vs a arms | formulaD106 | Suspension - Wheels & Tires | 4 | 01-21-2009 09:01 PM |
| team-moto trailing arms | hodakaracer | Seller/Buyer/Dealer Feedback | 2 | 10-24-2008 11:40 AM |
| Trailing arms | elmariachi | Suspension - Wheels & Tires | 18 | 07-23-2007 12:36 AM |
| Semi trailing arms and full trailing arms | oldskoolracer | MiniBuggy.net Lounge! | 4 | 01-09-2006 08:12 AM |
