The Drawing Room Discuss and share all your AUTOCAD information and ideas here. Design that perfect mini-buggy before you cut the first tube.
Old 11-02-2009, 04:30 PM   #51 (permalink)
yoshi's Avatar
Default Re: Sheet metal formed trailing arms - WHAT THICKNESS
Need to make sure the upright mounts (top to bottom) are at least an inch bigger than the mounts on the frame, maybe more depending on your application. If you don't, the top of the tire will tilt in at full extension, which will cost you a ton of travel as the outer cv will be your limiting factor due to the increased angle from the wheel tilting in......
I know, you've already got it built, so you've got some head scratching to do now, lol....
www.sinistersandsports.com
Old 11-02-2009, 05:32 PM   #52 (permalink)
jersdunz's Avatar
Send a message via MSN to jersdunz Send a message via Yahoo to jersdunz
yea that definitely would a been good to know two weeks ago. Cause I had the frame mounts lasered with the wrong hole size for the pivot bolts and just had them recut last sat. .. damn I guess I could take an inch out of those ( frame plates ) and have it like your saying but then would the axle still fit through....crap Tooo many little things that can jack you all up on these long travel buggies I really wish i woulda just gone standard travel
Sadly I have Officially Abandoned my lonely Buggy for 2 Years
and now I have the Itch and a broken dusty car....
jersdunz is offline   Reply With Quote
Old 11-02-2009, 06:35 PM   #53 (permalink)
jersdunz's Avatar
yea i just made the changes you speak of in my model and i see exactly what your talking about.
And on my next buggy I am going to do that...lol I don't care if i loose three inches I have had this car since 09 and it has less that 3 full hours of run time .. I want it done and driving.. lol I am so over wanting to work on any of it
Old 11-02-2009, 06:52 PM   #54 (permalink)
yoshi's Avatar
I'd actually just build new hubs, since going bigger on the hub will be stronger than going down on the frame, but don't just add length to the top or bottom, you have to space it out equally between the top and bottom otherwise it will cause the axle to not be inline with the suspension, which may over extend your axles.....
Quick question about trailing arms andy777bmx Suspension - Wheels & Tires 10 01-23-2009 02:32 AM
trailing arms vs a arms formulaD106 Suspension - Wheels & Tires 4 01-21-2009 09:01 PM
team-moto trailing arms hodakaracer Seller/Buyer/Dealer Feedback 2 10-24-2008 11:40 AM
Trailing arms elmariachi Suspension - Wheels & Tires 18 07-23-2007 12:36 AM
Semi trailing arms and full trailing arms oldskoolracer MiniBuggy.net Lounge! 4 01-09-2006 08:12 AM
