The Drawing Room Discuss and share all your AUTOCAD information and ideas here. Design that perfect mini-buggy before you cut the first tube.
Old 07-29-2009, 02:20 PM   #21 (permalink)
jersdunz's Avatar
Send a message via MSN to jersdunz Send a message via Yahoo to jersdunz
Default Re: Sheet metal formed trailing arms - WHAT THICKNESS
Also I was thinking on this last night and wondered what I could gain by moving my pivot point further back on the frame like so. The one i have posted just so darn long in comparison to what most people seem to be running.
Sadly I have Officially Abandoned my lonely Buggy for 2 Years
and now I have the Itch and a broken dusty car....
jersdunz is offline   Reply With Quote
Old 07-29-2009, 03:41 PM   #22 (permalink)
yoshi's Avatar
Originally Posted by jersdunz View Post
Yoshi while I'm thinking about it, What are the bolt circle dimensions i would need to use that would let your outers bolt in when my Subaru stuff gives out on me? bc dia?, hole size? how many holes?
If your talking about the bearing carrier specs, they're a 6 on 5-1/4" bolt pattern for 3/8" bolts......
www.sinistersandsports.com
yoshi is online now   Reply With Quote
Old 07-29-2009, 04:48 PM   #23 (permalink)
bdkw1's Avatar
Wait, your going from 5 link to trailing arms?
Old 07-29-2009, 06:08 PM   #24 (permalink)
jersdunz's Avatar
yea i have 550s buckS worth of heims on just the rear end that I really don't want to buy again
perfect yoshi thanks What is the dia of the thru hole?
Old 07-29-2009, 06:41 PM   #25 (permalink)
jersdunz's Avatar
The other night when I tore the rear end off my car the heims were letting the outside hub wiggle enough that my wheel could be wiggled close to 3/16".
I had such a terrible vibration in my car that the engine was bouncing almost an inch inside the chassis and two of my mounts are welded in!
I believe getting rid of the loose hiems will cure my vibration issue.
Also I am goint to install b-pillars and a new sinister drive spool.
If i had some more cash I'd be making it two seater as well. I think that qualifies a new chassis though. If i get the house I am trying to buy, maybe this winter I could do that.
Old 07-29-2009, 08:01 PM   #26 (permalink)
yoshi's Avatar
The rings I have plasma cut are as follows:
6-1/4 od
3-3/4 id
I actually have my machinist drill out all the rings in the cnc though....
Old 07-29-2009, 08:40 PM   #27 (permalink)
jersdunz's Avatar
6-1/4 od
3-3/4 id
SO COOL!! that will make switching them easy as pie in the event the subaru xt shafts are too weak and I need stronger components.
Old 07-29-2009, 09:03 PM   #28 (permalink)
I think you are making a big mistake but it is your car, my guess would be the rod ends on the car were cheap garbage when new.
MC@ Performance Fab is offline   Reply With Quote
Old 07-29-2009, 11:37 PM   #29 (permalink)
jersdunz's Avatar
Please explain why you think trailing arms are a mistake?
Old 07-30-2009, 07:35 AM   #30 (permalink)
bdkw1's Avatar
Axle plunge, camber curve, adjustability, weight, localized force loading......
I'm with Monte on this one. Good hiems with booties or seals should last for years.
Better weld in a LARGE tube like the one pictured on page 2 to keep the frame from cracking in the middle.
Quick question about trailing arms andy777bmx Suspension - Wheels & Tires 10 01-23-2009 02:32 AM
trailing arms vs a arms formulaD106 Suspension - Wheels & Tires 4 01-21-2009 09:01 PM
team-moto trailing arms hodakaracer Seller/Buyer/Dealer Feedback 2 10-24-2008 11:40 AM
Trailing arms elmariachi Suspension - Wheels & Tires 18 07-23-2007 12:36 AM
Semi trailing arms and full trailing arms oldskoolracer MiniBuggy.net Lounge! 4 01-09-2006 08:12 AM
