Old 12-02-2008, 01:22 AM   #1 (permalink)
Default Touchy clutch................
robndeb is offline   Reply With Quote
Old 12-02-2008, 01:36 AM   #2 (permalink)
plkracer's Avatar
Default Re: Touchy clutch................
You should only be pulling the cable on a bike clutch about 1/2 inch. The throw at the foot should be around 3-4 inches. I have a feeling that you are only moving the cable a tiny bit, and it is locking up too fast.
Old 12-02-2008, 02:00 AM   #3 (permalink)
Old 12-02-2008, 02:07 AM   #4 (permalink)
nutz4sand's Avatar
If its hydraulic are you SURE that all the air is out of it? A system with air in it may do what you are expieriencing. You may also be right on with the size difference. Do you know the differance between the stock master the motor HAD vs what you have now?
Sand! The only gold I need!
Old 12-02-2008, 02:07 AM   #5 (permalink)
yoshi's Avatar
Throw on my clutch is less than an inch, that's normal and you get use to it.......
www.sinistersandsports.com
Old 12-02-2008, 03:23 AM   #6 (permalink)
Old 12-02-2008, 03:31 AM   #7 (permalink)
Admin
Gene's Avatar
If your car does not already have one, a clutch slave cylinder support bracket will protect the sidcase from your big foot and leg pushing on a clutch requiring hand strength. Sidecases break so protect it.
Can you install a limit bolt on the clutch pedal to limit throw? Doing that will protect the sidecase. With that set you could depress the clutch to the stop and not cause damaging overpressure. You would also know where to anticipate the clutch.
Old 12-02-2008, 03:50 AM   #8 (permalink)
Old 12-02-2008, 03:51 AM   #9 (permalink)
If your car does not already have one, a clutch slave cylinder support bracket will protect the sidcase from your big foot and leg pushing on a clutch requiring hand strength. Sidecases break so protect it..
Old 12-02-2008, 04:37 PM   #10 (permalink)
Admin
Gene's Avatar
Contact Scott Horner at Heads-up performance. Phone: (714) 871-1940
Ask for the clutch slave cylnider bracket.
Busa motor flywheel. masterfabr Driveline 44 06-15-2009 06:31 PM
Driven CVT Clutch to Gearbox Mating SCBaja Driveline 18 11-11-2008 12:25 AM
Hand clutch Ideas... whiplash Controls and electrical 14 02-12-2008 02:53 PM
clutch tacklebox Motor - Engine 4 11-08-2007 09:27 PM
m/c hydro clutch to pedal hydro clutch ????? bajaBrothers Controls and electrical 11 06-18-2007 05:28 PM
